Can we create bandwidth limits for all users?
I want to share internet through my Ubuntu Server. Is this possible or not?
Sharing Internet Connection is easy, and DpN has already provided a possible solution to that through a GUI. Alternatively, you can use iptables and masquerading to achieve the same, though it'll be without a GUI. More information can be had on http://www.tldp.org/HOWTO/IP-Masquerade-HOWTO/firewall-examples.html
Following is a sample script that you can run on the server. You can provide the gateway of this server to other machines so that they can access internet through this.
#!/bin/bash
echo -e "\n\nSETTING UP IPTABLES PROXY..."
INTIF="eth0"
EXTIF="eth1"
EXTIP="your.static.IP.address"
echo "Loading required stateful/NAT kernel modules..."
/sbin/depmod -a
/sbin/modprobe ip_tables
/sbin/modprobe ip_conntrack
/sbin/modprobe ip_conntrack_ftp
/sbin/modprobe ip_conntrack_irc
/sbin/modprobe iptable_nat
/sbin/modprobe ip_nat_ftp
/sbin/modprobe ip_nat_irc
echo " Enabling IP forwarding..."
echo "1" > /proc/sys/net/ipv4/ip_forward
echo " Loading proxy server rules..."
# Clearing any existing rules and setting default policy
iptables -P INPUT ACCEPT
iptables -F INPUT
iptables -P OUTPUT ACCEPT
iptables -F OUTPUT
iptables -P FORWARD DROP
iptables -F FORWARD
iptables -t nat -F
# FWD: Allow all connections OUT and only existing and related ones IN
iptables -A FORWARD -i $EXTIF -o $INTIF -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -A FORWARD -i $INTIF -o $EXTIF -j ACCEPT
# Enabling SNAT (MASQUERADE) functionality on $EXTIF
iptables -t nat -A POSTROUTING -o $EXTIF -j MASQUERADE
echo -e " Proxy server rule loading complete\n\n"
However, managing / limiting bandwidth (also called traffic shaping) is a different ball game. You would need to have some advanced knowledge of the tools to be used and what your needs would be. There are some external firwalls such as pfSense which help you manage it pretty well, but it'll require a different type of network setup.
