When I try to upgrade from Ubuntu Gnome 13.10 to Ubuntu 14.04, the upgrade application fails with the following message:
Could not calculate the upgrade.
An unresolvable problem occurred while calculating the upgrade.`
Here is the complete log:
$ cat /etc/issue
Ubuntu 13.10 \n \l
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo do-release-upgrade
Checking package manager
Reading package lists... Done
Building dependency tree
Building data structures... Done
Calculating the changes
This can be caused by:
* Upgrading to a pre-release version of Ubuntu
* Running the current pre-release version of Ubuntu
* Unofficial software packages not provided by Ubuntu
If none of this applies, then please report this bug using the
command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal.
Restoring original system state
Aborting
Am I missing something? or it is just a bug?
UPDATE:
I analyzed the log file and found that do-release-upgrade is complaining about some obsolete packages.
$ cat /var/log/dist-upgrade/main.log | grep Obsolete
2014-04-28 09:16:23,678 DEBUG Obsolete: flashplugin-nonfree-extrasound:i386 (..)
After removing those packages, I was able to proceed with the upgrade.
