I have Windows 8 installed in C drive (by default from Lenovo) & Ubuntu separately installed in another partition.
When I start my computer it leads straight to the GRUB menu. There I can see options to load Ubuntu and Windows 8.
When I select Ubuntu it works fine, but when I select Windows 8 option, then it leads straight back to the GRUB menu.
Hence I am unable to boot into Windows 8 via the GRUB menu (the only way I can boot into Windows 8 is by using the one touch recovery button).
Zanna
  • 72,312
user274700
Boot Ubuntu. Try opening a terminal by holding down CTRL and ALT and tapping T and then issue the command
sudo update-grub
This should find your windows 8 installation again. If this doesn't work it's possible you've overwritten your Windows 8 boot sector which you would need to repair with windows 8 media and then reinstall grub (making sure you don't overwrite the windows boot sector again) so you can boot ubuntu.
Elder Geek
  • 36,752
