Using Ubuntu 14.04 LTS.
sudo apt-get update
thats all i ran, and it'd start off real smooth, then it'd get to a part where it gets stuck for like a fair ammount of time after which it'd display this error.
W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty/restricted amd64 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty_restricted_binary-amd64_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty/restricted i386 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty_restricted_binary-i386_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-updates/restricted amd64 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-updates_restricted_binary-amd64_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-updates/restricted i386 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-updates_restricted_binary-i386_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-backports/restricted amd64 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-backports_restricted_binary-amd64_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-backports/multiverse amd64 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-backports_multiverse_binary-amd64_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-backports/restricted i386 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-backports_restricted_binary-i386_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-backports/multiverse i386 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-backports_multiverse_binary-i386_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-security/restricted amd64 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-security_restricted_binary-amd64_Packages)
    W: Duplicate sources.list entry http://archive.ubuntu.com/ubuntu/ trusty-security/restricted i386 Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty-security_restricted_binary-i386_Packages)
    W: You may want to run apt-get update to correct these problems
of course the suggestion it suggested isnt going to work, as it's that very command after running which i came across the error. I've tried creating a new sources.list file, and also, in the 'other software' tab in the updater settings, i found two "canonical Partners" and thus i eradicated one of them. Still it wont work. there are a number of lists that the error tells of... I checked one and couldnt make any sense out of it.
Also, I installed the 32bit architecture manually so as to be able to use skype
You state: "Also, I installed the 32bit architecture manually so as to be able to use skype" If you need full compatibility with 32 bit code you should install the i386 version. Regardless you can solve this problem by carefully editing /etc/apt/sources.list
sudo gedit /etc/apt/sources.list
make sure every repository appears once and only once.
or copy the original sources.list file from a live cd/dvd/usb at the same location. Or even better consult this: How to fix Duplicate sources.list entry? A closer look at your warnings make it clear. Look closely at this example and you'll see you have dusplicate sources for differing architectures:
Elder Geek
  • 36,752
As Elder Greek observes you have both i386 32 bit and amd_64 bit entries. If you have synaptic or
sudo apt-get install synaptic
when you run it under Settings → Repositories → Other Software you will find the list of all your repositories.
Delete the i386 entries and Reload (update).
If there are any more duplicates it will tell you so you can check and delete.
