I am a linux newbie, tech oldie.
I am setting up a system with Lubuntu 14.04. Although, when I ran the installation I created two partitions -- 1/2 for quickie backups and 1/2 for the installed system -- lubuntu ignored that and took my entire disk.
Yesterday, I spent a lot of time with the Redo Rescue disk manually recreating what I wanted.
Now, I have the following paritions:
/dev/sda1 ext2 /boot +- 200MB
/dev/sda2 extended +- 244GB
/dev/sda3 ext2 +- 220GB
sda1 and sda2 were created by the installer. I manually created sda3 after resizing those.
within sda2 is a logical volume
sda5 lvm2 pv lubuntu-vg
within sda 5 there are a swap partion and the root partition and nothing else. these were also created by the installer, but I resized them yesterday.
I want to backup sda1 and sda2 to sda3. I have been at this long enough to know that gives me zero protection from a disk failure. I just want to quickly be able to restore my work up to a certain point if I screw something up as I am tweaking the new system.
I have the qt4-fsarchiver LiveCD, the SystemRescueCD LiveCD and the Redo Rescue LiveCD. As a linux newbie, I have been unable to figure out how to do this on any of these.
SuB
  • 4,419
Warning: Any time you deal with partitions, you should be very careful, since data might get destroyed.
Try dd.
Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
dd if=/dev/sda1 of=/dev/sdb1 bs=4096 conv=notrunc,noerror,sync
To clone a partition
OR
dd if=/dev/sda of=/dev/sdb bs=4096 conv=notrunc,noerror,sync
To clone an entire hard disk
For more info see dd Man Page 1 & Man Page 2
Mitch
  • 109,787
