How can I run a VPN connection on a non-standard port? I have set up a VPN on my router running DD-WRT which I connected to my main router. I have forwarded the port to port 90 and can not connect to the VPN with the Network Manager. If I change the port back to 1723 (the default port) I can connect just fine. Does anybody know how to fix this?
Here are the relevant IP addresses:
1.1.1.1=DD-WRT Router
192.168.1.154=IP on Internet Router
64.7.134.78=IP
I want it to work like this:
1.1.1.1:1723 > 192.168.1.154:1723 > 64.7.134.78:90
But it will only work like this:
1.1.1.1:1723 > 192.168.1.154:1723 > 64.7.134.78:1723
david6
  • 14,528
  • 38
  • 46
It sounds as though you have forwarded the port to port 90 on the DD-WRT, is that correct? Have you checked your iptables configuraton on the DD-WRT to ensure that your packets to that port will be received?
I don't currently know how to get Network Manager to PPTP to a specific port. I am looking into it and I will edit this answer when I find out. You also might try appending the port number to the end of the IP address, like 192.168.1.1:90 for example.
I can't find any way to induce Network Manager to send to a custom port, unless the above suggestion works.
Looking at /usr/share/doc/pptp-linux/USING and at man pppd I don't see any way to specify a custom port either, unless, again, the method above works.
If it does not work, the best thing I can think of is to add a static route, defining the VPN's address range as the destination and the VPN tunnel exit address and port as the gateway. See ip route help for more information.
koanhead
  • 6,547
