Firstly, Wi-Fi works 100% of the time on my Ubuntu netbook, my Android phone and my Windows install (on the same computer/USB-wifi device), so I don't think this can be a router issue... It would be strange if it were a driver issue as it sometimes connects, but FYI the USB-wifi device is a Edimax EW-7318USg.
Second, if it does connect (during this session) then it connects first time, else it will not connect (no matter how long I try). Wi-Fi does connect about 20% of the time (restarting the computer about 5 times usually allows me to connect). Once it has connected it stays connected (until restarted).
Obviously it is hugely irritating! Any ideas how I can remedy this?
EDIT: As requested, the results of running sudo lshw -class Network:
description: Ethernet interface
product: MCP77 Ethernet
vendor: nVidia Corporation
physical id: a
bus info: pci@0000:00:0a.0
logical name: eth0
version: a2
serial: 00:19:66:d3:fe:21
capacity: 1Gbit/s
width: 32 bits
clock: 66MHz
capabilities: pm msi ht bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=forcedeth driverversion=0.64 latency=0 link=no maxlatency=20 mingnt=1 multicast=yes port=MII
resources: irq:41 memory:fcf7c000-fcf7cfff ioport:c880(size=8) memory:fcf7e400-fcf7e4ff memory:fcf7e000-fcf7e00f
*-network
description: Wireless interface
physical id: 1
bus info: usb@1:2
logical name: wlan0
serial: 00:0e:2e:4d:ff:b4
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rt73usb driverversion=2.6.38-8-generic firmware=1.7 ip=192.168.2.6 link=yes multicast=yes wireless=IEEE 802.11bg
Is this a known bug or should it be filed as one? (if so, which or against what?).
