Is it possible to change the font or at least the font size of text in Unity's indicator panel (for things like the clock and system indicator monitor) without changing Application Font size from the Appearance Preferences > Fonts settings? I'm using a small monitor and I'd like just a wee bit more space for the global applications menu.
Asked
Active
Viewed 1.6k times
This not the best way as it involves changing the size for all applications, but it's the only way I know.
- Press Alt + F2 and type
gnome-appearance-properties. - Start the Appearance Preferences application from the search result.
- Go to the Fonts tab.
- Change the Application Fonts font settings.
htorque
- 66,086
MyUnity
In the Fonts section of MyUnity, you can set the System, Desktop, and Window Title fonts to configure this.
Jjed
- 14,064
MyUnity isn't yet available for 12.10, so you might want to try gnome-tweak-tool if you're using that. gnome-tweak-tool of course will only work for changing system-wide default fonts.
Thomas Dignan
- 113
