79
I've done tons of search and tested different solutions, but gain no success!
When I want to push my codes, I receive the following error:
Warning: the ECDSA host key for 'git.mywebsite.ir' differs from the key for the IP address '164.138.23.11'
Offending key for IP in /home/alireza/.ssh/known_hosts:10
Matching host key in /home/alireza/.ssh/known_hosts:1
Are you sure you want to continue connecting (yes/no)? yes
What should I do to remove this message every time I push my changes? Any idea?
key list
Alireza
  • 1,294
  • 14
  • 26
It says:
So for some reason you have to delete 10-th line in known_hosts.
Run this command to delete 10-th line in known_hosts:
sed -i '10d' ~/.ssh/known_hosts
Or use ssh-keygen
ssh-keygen -R git.mywebsite.ir
Quote from man
 -R hostname
         Removes all keys belonging to hostname from a known_hosts file.
         This option is useful to delete hashed hosts (see the -H option
         above).
c0rp
  • 10,010
When I got the messages:
Offending key for IP in /home/myusername/.ssh/known_hosts:12
Notice the line number - in my case - 12
So open 'known_hosts' file and delete the 12-th row.
For me this solved the problem.
P.s. Notice if you cannot find the .ssh folder - the .ssh folder is hidden and in order to see it from the file manager - you have to "Show hidden files and folders". In Linux Mint (and possible in your distro too) when in the file manager - there is a shortcut to show/hide hidden folders -> Ctrl+H
Cheers
Combine
  • 169
You have to edit your known_hosts file (located in ~/.ssh/known_hosts) and remove an entry asociated with this address.
kulak
  • 109
