I just upgraded from Ubuntu 13.10 to 14.04, but now I cant login and see my desktop. I get all the way to the login screen and enter my password, but after pressing enter I get left with the 14.04 LTS splash screen. I get the same when trying to login as guest.
I can press CTRL-ALT-F1 and login on the terminal. From the terminal I checked that I'm using the proprietry driver (nvidia 331 (proprietry, tested)).
When I tried to run unity from the terminal I see the error "compiz: open gl not loaded"
Any ideas much appreciated.
UPDATE: Is this heading the way of save me stuff from the terminal and fresh install 14.04?
FIX: For people following in my footsteps the fix can be found here
after login to the terminal , try to rm ~/.Xauthority and then reboot I had a similar issue and that was the solution
Fat Mind
  • 2,485
