159
Is there a way speed up Linux CLI navigation when I must enter long commands? I simply use arrows right now, and - if I have a long command it takes some time to get from start of the command to the middle of it.
Is there a way to for example jump to the middle of the command without using arrows?
Luis Alvarado
  • 216,643
Stann
  • 15,416
5 Answers5
205
Some useful line editing key bindings provided by the Readline library:
  • Ctrl + A: go to the beginning of line
  • Ctrl + E: go to the end of line
  • Alt + B: skip one word backward
  • Alt + F: skip one word forward
  • Ctrl + U: delete to the beginning of line
  • Ctrl + K: delete to the end of line
  • Alt + D: delete to the end of word
damadam
  • 2,873
Adam Byrtek
  • 9,861
90
Some more shortcuts from here
Ctrl + a  – Go to the start of the command line
Ctrl + e  – Go to the end of the command line
Ctrl + k  – Delete from cursor to the end of the command line
Ctrl + u  – Delete from cursor to the start of the command line
Ctrl + w  – Delete from cursor to start of word (i.e. delete backwards one word)
Ctrl + y  – Paste word or text that was cut using one of the deletion shortcuts (such as the one above) after the cursor
Ctrl + xx – Move between start of command line and current cursor position (and back again)
Alt  + b  – Move backward one word (or go to start of word the cursor is currently on)
Ctrl+Alt+b – Move backward one word (a word can contain punctuation)
Alt  + f  – Move forward one word (or go to end of word the cursor is currently on)
Ctrl+Alt+f – Move forward one word (a word can contain punctuation)
Alt  + d  – Delete to end of word starting at cursor (whole word if cursor is at the beginning of word)
Alt  + c  – Capitalize to end of word starting at cursor (whole word if cursor is at the beginning of word)
Alt  + u  – Make uppercase from cursor to end of word
Alt  + l  – Make lowercase from cursor to end of word
Alt  + t  – Swap current word with previous
Ctrl + f  – Move forward one character
Ctrl + b  – Move backward one character
Ctrl + d  – Delete character under the cursor
Ctrl + h  – Delete character before the cursor
Ctrl + t  – Swap character under cursor with the previous one
Rock
  • 28
karlacio
  • 1,282
17
If you're a vi[m] and bash user, you may find it useful to make readline (used by bash) use vi-style editing by adding set editing-mode vi to your ~/.inputrc or /etc/inputrc files. Or, you could just make bash use vi-style editing by running the bash command set -o vi. Add the command to your ~/.bashrc file to make the behavior persistent.
If you're a zsh user, add bindkey -v to your .zshrc file for vi-style editting.
I do not know of a way to specifically jump to the middle without using the cursor keys. However, I can recommend using Ctrl + cursor key to move from blank to blank (i.e., jump from one word to another).
Pablo Bianchi
  • 17,371
Kory Wnuk
  • 1,521
Source the code-snippet below in your .bashrc. Ctrl-a jumps to the start and pressing Ctrl-a again jumps to the middle.
jump_mid() {
    if [ "$READLINE_POINT" -eq "0" ]; then
        LEN=${#READLINE_LINE}
        POS=$(($LEN / 2))
        READLINE_POINT=$POS
    else
        READLINE_POINT=0
    fi
bind -x '"\C-a" : jump_mid'
Or if you want to use Ctrl-Something to directly jump to the middle, change the code to:
jump_mid() {
    POS=$(($LEN / 2))
    READLINE_POINT=$POS
And bind it to something different than Ctrl-a.
marukse
  • 51
