I have installed hadoop-2.4.0 in my 14.04 LTS,
I have followed this link, I have done upto start and stop services successfully,
but when I tried to execute example,
$ /bin/hadoop jar hadoop*examples*.jar wordcount /user/hduser/gutenberg /user/hduser/gutenberg-output
and I am getting response as,
Not a valid JAR: /hadoop*examples*.jar
EDIT 1
I have installed JAVA 7(i.e JDK 1.7) and when I used Hadoop-1.0.3 it works fine.
Problem cause when I try to execute with Hadoop-2.4.0.
NOTE
From this tutorial my system differ the following,
  1. I am using JAVA 7 instead of JAVA 6.
  2. I am using Hadoop 2.4.0 instead of Hadoop-1.0.3
  3. I am usinh Ubuntu 14.04 instead of Ubuntu 10.04.
And I can successfully execute HAdoop-1.0.3 with JAVA 7 on 14.04.
My question why can't I run the same for Hadoop-2.4.0.
A J
  • 11,557
I had the same problem. Here is the solution.
OS - Ubuntu 14.04 64-bit
Java - OpenJDK 7
Hadoop - Hadoop 2.4.1
Step 1: create a hdfs directory for input: hadoop dfs -mkdir -p /usr/local/hadoop/input
Step 2: now paste the jar file into this folder using hadoop command.
hadoop dfs -copyFromLocal /home/hduser/Desktop/sample.txt /usr/local/hadoop/input
Step 3: Go to $HADOOP_HOME/share/hadoop/mapreduce folder in terminal.
cd $HADOOP_HOME/share/hadoop/mapreduce
hadoop jar hadoop-mapreduce-examples-2.4.1.jar wordcount /usr/local/hadoop/input/sample.txt /usr/local/hadoop/output
Here /usr/local/hadoop/output folder will be created. Each time you have to give a new name.
NOTE: you cannot simply list the folders input and output using ls in terminal.
Step 4: To view the output, use this:
hadoop dfs -cat /usr/local/hadoop/output/part-r-00000
I was also following the same tutorial and faced same issue with my latest install (hadoop 2.7.1). I had to change it from
to
$ /bin/hadoop jar ./share/hadoop/mapreduce/hadoop-*-examples*.jar  wordcount /user/hduser/gutenberg /user/hduser/gutenberg-output
maicalal
This tutorial has been tested with the following software versions:
Ubuntu Linux 10.04 LTS (deprecated: 8.10 LTS, 8.04, 7.10, 7.04)
It hasn't been updated since 10.04 ~ 2012. That is (I would guess your problem).
14.04 and 10.04 work quite differently...
Sun Java 6
Sun Java is no longer avaliable in Ubuntu so that is also probably why it isn't working.
Tim
  • 33,500
-1
I am using the hadoop-2.7.2 and to handle this problem, simply go to the directory hadoop-2.7.2 and instead of writing directly hadop*exaples*jar write the following:
share/hadoop/mapreduce/hadoop-mapreduce-examples-2.7.2.jar
David Foerster
  • 36,890
  • 56
  • 97
  • 151
