I've google searched heaps and tried all the options so far, but nothing seems to work. Windows 7 does not show up on the grub loader after installing Ubuntu 14.04.
I've tried editing /etc/grub.d/40_custom by adding:
menuentry "Windows 7 UEFI" {
    search --fs-uuid --no-floppy --set=root 5761-0BA2
    chainloader (${root})/efi/Microsoft/Boot/bootmgfw.efi
but the grub loader just says:
error: file `/efi/Microsoft/Boot/bootmgfw.efi` not found
I ran bootinfoscript and this is my output (the EFI partition appears to be sda6): http://pastebin.com/4rzxPTC4
I'm at a loss. Any help?
hashi
  • 13
You have a GPT disk and no sign of a Windows boot loader installed on your EFI System Partition (ESP; your /dev/sda5), but Boot Info Script is reporting a BIOS-mode Windows boot loader installed on the disk's MBR. You do seem to have an EFI-mode version of GRUB on the disk. This combination makes me think that you started with an MBR disk, converted it to GPT, and installed Ubuntu in EFI mode. If I'm right about this, you won't get it to boot as it is, because Windows will boot only in EFI mode from a GPT disk, so you must first install an EFI boot loader for Windows. See this page for information on how to do this. You've already done much of what needs to be done, so you should be able to start with step 3.5 (although it refers to a backup created in step 3.1, so check it out, too).
Rod Smith
  • 45,120
  • 66
  • 108
