I have a PDF file containing 100 pages. I would like to extract those pages containing a particular string.
How can I achieve this? Maybe by using ghostscript on the command line?
For what it's worth: I am using Edubuntu 12.04 LTS.
Overview
Here's a script I quickly put together which should do the job. Make sure to read the preamble and the comments for information on how to use the script and how it works.
Script
#!/bin/bash
# NAME: extract_pdf_results
# VERSION: 0.1
# AUTHOR: (c) 2014 Glutanimate
# DESCRIPTION: Extracts PDF pages that contain supplied string and concatenates them to a new file.
# FEATURES:
# DEPENDENCIES: pdfgrep pdftk
# ➥install on Ubuntu/Debian with sudo apt-get install pdfgrep pdftk
# LICENSE: GNU GPLv3 (http://www.gnu.de/documents/gpl-3.0.en.html)
# NOTICE: THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
# EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
# PROVIDE THE PROGRAM “AS IS” WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR
# IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
# AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND
# PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE,
# YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
# IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING WILL ANY
# COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MODIFIES AND/OR CONVEYS THE PROGRAM AS
# PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL,
# INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE
# THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING RENDERED
# INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A FAILURE OF THE
# PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS), EVEN IF SUCH HOLDER OR OTHER
# PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
# USAGE: extract_pdf_results <string> <pdffile>
STRING="$1"
FILE="$2"
FILENAME="${FILE##*/})"
BASENAME="${FILENAME%.*}"
DIRNAME="${FILE%/*}"
echo "Processing $FILE..."
## find pages that contain string, remove duplicates, convert newlines to spaces
echo "Looking for $STRING..."
PAGES="$(pdfgrep -n "$STRING" "$FILE" | cut -f1 -d ":" | uniq | tr '\n' ' ')"
echo "Matching pages:
$PAGES"
## extract pages to new file in original directory
echo "Extracting result pages..."
pdftk "$FILE" cat $PAGES output "${DIRNAME}/${BASENAME}_pages_with_${STRING}.pdf"
echo "Done."
Example
./extract_pdf_results.sh Lagrange ./test.pdf
Processing ./test.pdf...
Looking for Lagrange...
Matching pages:
Done.
