So, I'm using Ubuntu desktop and have installed Apache, PHP and MySQL, all working great.
I want to use start adding files and folders to /var/www using the file manager, but my user doesn't have permissions to do this.
Any ideas what permissions I need to update?
mmyers
  • 184
JamesA
  • 103
Create a directory in your home, ie:
mkdir ~/my_dir
then, create a symbolic link in /var/www/:
ln -s ~/my_dir /var/www/my_dir
This allows you to write to the directory. If apache needs to access, you must change the group to all the directories where you want this to happen:
sudo chown -R <user>:www-data ~/my_dir
girardengo
  • 5,005
Try this:
sudo adduser <username> www-data
sudo chown -R www-data:www-data /var/www
sudo chmod -R g+rw /var/www
The user should be able to edit /var/www/ without any problems.
Cody
  • 364
You may also start nautilus as root:
sudo -i nautilus &
Seth
  • 59,332
