New user trying to update software but don't know the authentication pass word
The authentication password is your own password.
You can change it in system preferences or using passwd.
- 364
the authentication password is your current user password.
if you want to change the password to be sure use this command :
sudo passwd user_name
then click enter it will ask you for the new password and ask you to verify it
if you want to activate root user just use this command :
sudo passwd
without writing a user name and it will set password for root user and activate it then you login with it in cmd by using this command :
sudo su -
and by then you wont use sudo any more and can use the root password for authentication
- Start your computer
- In a grub menu which appear by default when your start your computer, select "advanced options for ubuntu"
- After that, select the option which states things like "recovery mode"
- Now You will be shown the recovery menu. In the recovery menu Select “root – Drop to root shell prompt
Then command prompt will appear at the bottom of the screen. Type this following in the command prompt to show all the user of your computer
ls /homeNext type the following command at command prompt to mount with permissions
mount -rw -o remount /Finally type
passwd usernamein the command prompt. For example if the username you selected is Kevin, the command will bepasswd KevinIt will ask you to reset password
Enter new UNIX Password:Retype new UNIX Password:Make sure you see this message
Passwd:Password updated successfullyJust it ! Now restart your computer by type
rebootin the command prompt
- 15,677
