15
installing man1/cms.1
cms.pod around line 457: Expected text after =item, not a number
cms.pod around line 461: Expected text after =item, not a number
cms.pod around line 465: Expected text after =item, not a number
cms.pod around line 470: Expected text after =item, not a number
cms.pod around line 474: Expected text after =item, not a number
POD document had syntax errors at /usr/bin/pod2man line 71.
make: *** [install_docs] Error 255
I get this error when trying to build from source on ubuntu 14.04.
-thanks!
from this page:
Changing
make install
to
make install_sw
(installing OpenSSL without the man pages) alleviates this issue.
Yaron
  • 13,453
N. S.
  • 381
POD files found to be generated with a lot of errors from the perl 5.18 point of view. See the patch here https://github.com/openssl/openssl/issues/57
fedya
  • 29
Go to line specified in specified file (cms.pod) and change =item 1 to =item '1'.
I figured this out after trying to install openssl0.9.8 for guitar pro 6.
Edit:
SSL_CTX_load_verify_locations.pod around line 109: Expected text after =item, not a number
If you are having the problem with openssl0.9.8 and guitar pro 6, there are a lot of files to update. If there is a away to mass edit these files O_O so much want
David Foerster
  • 36,890
  • 56
  • 97
  • 151
"The latest stable version is the 1.0.2 series of releases. This is also our Long Term Support (LTS) version (support will be provided until 31st December 2019). The 1.0.1 version is currently only receiving security bug fixes and all support will be discontinued for this version on 31st December 2016. Our newest version is 1.1.0 which is currently in alpha testing and should not be used for production purposes at this time. The 0.9.8 and 1.0.0 versions are now out of support and should not be used."
Try using the supported version here.
DnrDevil
  • 1,478
