Im having a lot of problems with my Ubuntu after the update from the 12.04 LTS to 14.04 LTS.
Every time I start the system, it shows a lot of dialogs saying that the system encountered problems, and it gives me the options "OK" and "Report the problem".
Also, my main problem is with apt-get not working. For example, when an upgrade is executed, it shows problems related to pages of Latex, as follows:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
libdb5.1-java libdb5.1-java-jni
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
78 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up tex-common (4.04) ...
Ignoring /etc/texmf/texmf.d/05TeXMF.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/15Plain.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/45TeXinputs.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/55Fonts.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/65BibTeX.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/75DviPS.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/80DVIPDFMx.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/85Misc.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/90TeXDoc.cnf during generation of texmf.cnf, please remove manually!
Ignoring /etc/texmf/texmf.d/95NonPath.cnf during generation of texmf.cnf, please remove manually!
Running mktexlsr. This may take some time... done.
Running updmap-sys. This may take some time...
updmap-sys failed. Output has been stored in
/tmp/updmap.F4dMHt02
Please include this file if you report a bug.
Sometimes, not accepting conffile updates in /etc/texmf/updmap.d
causes updmap-sys to fail. Please check for files with extension
.dpkg-dist or .ucf-dist in this directory
dpkg: error processing package tex-common (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of latex-sanskrit:
latex-sanskrit depends on tex-common (>= 3); however:
Package tex-common is not configured yet.
dpkg: error processing package latex-sanskrit (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of lmodern:
lmodern depends on tex-common (>= 3); however:
dpkg: error processing package lmodern (--configure):
dpkg: dependency problems prevent configuration of tex-gyre:
tex-gyre depends on tex-common (>= 3); however:
dpkg: error processing package tex-gyre (--configure):
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of texlive-latex-base:
texlive-latex-base depends on tex-common (>= 3); however:
dpkg: error processing package texlive-latex-base (--configure):
dpkg: dependency problems prevent configuration of texlive-latex-recommended:
texlive-latex-recommended depends on texlive-latex-base (>= 2013.20130512); however:
Package texlive-latex-base is not configured yet.
texlive-latex-recommended depends on tex-common (>= 3); however:
dpkg: error processing package texlive-latex-recommended (--configure):
dpkg: dependency problems prevent configuration of cm-super-minimal:
cm-super-minimal depends on tex-common (>= 3); however:
cm-super-minimal depends on texlive-latex-recommended; however:
Package texlive-latex-recommended is not configured yet.
dpkg: error processing package cm-super-minimal (--configure):
dpkg: dependency problems prevent configuration of cm-super:
cm-super depends on tex-common (>= 3); however:
cm-super depends on texlive-latex-recommended; however:
cm-super depends on cm-super-minimal (= 0.3.4-9); however:
Package cm-super-minimal is not configured yet.
dpkg: error processing package cm-super (--configure):
dpkg: dependency problems prevent configuration of texlive-metapost:
texlive-metapost depends on tex-common (>= 3); however:
dpkg: error processing package texlive-metapost (--configure):
dpkg: dependency problems prevent configuration of context:
context depends on texlive-metapost (>= 2013); however:
Package texlive-metapost is not configured yet.
context depends on lmodern (>= 2.004.4); however:
Package lmodern is not configured yet.
context depends on tex-gyre; however:
Package tex-gyre is not configured yet.
context depends on tex-common (>= 4); however:
dpkg: error processing package context (--configure):
dpkg: dependency problems prevent configuration of context-modules:
context-modules depends on context (>> 2011); however:No apport report written because MaxReports is reached already
Package context is not configured yet.
context-modules depends on tex-common (>= 3); however:
dpkg: error processing package context-modules (--configure):
dpkg: dependency problems prevent configuration of texlive-font-utils:
texlive-font-utils depends on tex-common (>= 3); however:
dpkg: error processing package texlive-font-utils (--configure):
dpkg: dependency problems prevent configuration of texlive-extra-utils:
texlive-extra-utils depends on tex-common (>= 3); however:
texlive-extra-utils depends on texlive-latex-base (>= 2013.20130512); however:
dpkg: error processing package texlive-extra-utils (--configure):
dpkg: dependency problems prevent configuration of feynmf:
feynmf depends on tex-common (>= 3); however:
feynmf depends on texlive-latex-base; however:
feynmf depends on texlive-font-utils; however:
Package texlive-font-utils is not configured yet.
feynmf depends on texlive-extra-utils; however:
Package texlive-extra-utils is not configured yet.
dpkg: error processing package feynmf (--configure):
dpkg: dependency problems prevent configuration of kile:
kile depends on texlive-latex-base; however:
dpkg: error processing package kile (--configure):
dpkg: dependency problems prevent configuration of latex-xcolor:
latex-xcolor depends on texlive-latex-recommended; however:
latex-xcolor depends on tex-common (>= 3); however:
dpkg: error processing package latex-xcolor (--configure):
dpkg: dependency problems prevent configuration of latex-beamer:
latex-beamer depends on tex-common (>= 4); however:
latex-beamer depends on latex-xcolor (>= 2.00-1); however:
Package latex-xcolor is not configured yet.
latex-beamer depends on texlive-latex-base; however:
Package texBest Regards,
dpkg: error processing package latex-beamer (--configure):
dpkg: dependency problems prevent configuration of latex-cjk-common:
latex-cjk-common depends on texlive-latex-base; however:
latex-cjk-common depends on texlive-font-utils (>= 2007.dfsg.2-1); however:
latex-cjk-common depends on tex-common (>= 4); however:
dpkg: error processing package latex-cjk-common (--configure):
dpkg: dependency problems prevent configuration of latex-cjk-chinese:
latex-cjk-chinese depends on latex-cjk-common (= 4.8.3+git20120914-2ubuntu1); however:
Package latex-cjk-common is not configured yet.
latex-cjk-chinese depends on tex-common (>= 3); however:
dpkg: error processing package latex-cjk-chinese (--configure):
dpkg: dependency problems prevent configuration of latex-cjk-japanese:
latex-cjk-japanese depends on latex-cjk-common (= 4.8.3+git20120914-2ubuntu1); however:
latex-cjk-japanese depends on tex-common (>= 4); however:
dpkg: error processing package latex-cjk-japanese (--configure):
dpkg: dependency problems prevent configuration of latex-cjk-korean:
latex-cjk-korean depends on latex-cjk-common (>= 4.8.3+git20120914-2ubuntu1); however:
latex-cjk-korean depends on tex-common (>= 4); however:
dpkg: error processing package latex-cjk-korean (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-other:
texlive-lang-other depends on tex-common (>= 3); however:
dpkg: error processing package texlive-lang-other (--configure):
dpkg: dependency problems prevent configuration of latex-cjk-thai:
latex-cjk-thai depends on latex-cjk-common (>= 4.8.3+git20120914-2ubuntu1); however:
latex-cjk-thai depends on texlive-latex-base; however:
latex-cjk-thai depends on tex-common (>= 4); however:
latex-cjk-thai depends on texlive-lang-other (>= 2013.20130523-1); however:
Package texlive-lang-other is not configured yet.
dpkg: error processing package latex-cjk-thai (--configure):
dpkg: dependency problems prevent configuration of latex-cjk-all:
latex-cjk-all depends on latex-cjk-common (>= 4.8.3+git20120914-2ubuntu1); however:
latex-cjk-all depends on latex-cjk-chinese (>= 4.8.3+git20120914-2ubuntu1); however:
Package latex-cjk-chinese is not configured yet.
latex-cjk-all depends on latex-cjk-japanese (>= 4.8.3+git20120914-2ubuntu1); however:
Package latex-cjk-japanese is not configured yet.
latex-cjk-all depends on latex-cjk-korean (= 4.8.3+git20120914-2ubuntu1); however:
Package latex-cjk-korean is not configured yet.
latex-cjk-all depends on latex-cjk-thai (= 4.8.3+git20120914-2ubuntu1); however:
Package latex-cjk-thai is not configured yet.
dpkg: error processing package latex-cjk-all (--configure):
dpkg: dependency problems prevent configuration of latexmk:
latexmk depends on texlive-latex-base; however:
dpkg: error processing package latexmk (--configure):
dpkg: dependency problems prevent configuration of m-tx:
m-tx depends on tex-common (>= 4); however:
dpkg: error processing package m-tx (--configure):
dpkg: dependency problems prevent configuration of musixtex:
musixtex depends on tex-common (>= 4); however:
dpkg: error processing package musixtex (--configure):
dpkg: dependency problems prevent configuration of pmx:
pmx depends on tex-common (>= 4); however:
pmx depends on texlive-latex-base; however:
dpkg: error processing package pmx (--configure):
dpkg: dependency problems prevent configuration of purifyeps:
purifyeps depends on texlive-metapost; however:
dpkg: error processing package purifyeps (--configure):
dpkg: dependency problems prevent configuration of texlive-fonts-recommended:
texlive-fonts-recommended depends on tex-common (>= 3); however:
dpkg: error processing package texlive-fonts-recommended (--configure):
dpkg: dependency problems prevent configuration of texlive:
texlive depends on texlive-latex-recommended (>= 2013.20130512); however:
texlive depends on texlive-fonts-recommended (>= 2013.20130512); however:
Package texlive-fonts-recommended is not configured yet.
texlive depends on texlive-latex-base (>= 2013.20130512); however:
dpkg: error processing package texlive (--configure):
dpkg: dependency problems prevent configuration of texlive-bibtex-extra:
texlive-bibtex-extra depends on tex-common (>= 3); however:
texlive-bibtex-extra depends on texlive-latex-base (>= 2013.20130512); however:
dpkg: error processing package texlive-bibtex-extra (--configure):
dpkg: dependency problems prevent configuration of texlive-fonts-extra:
texlive-fonts-extra depends on tex-common (>= 3); however:
dpkg: error processing package texlive-fonts-extra (--configure):
dpkg: dependency problems prevent configuration of texlive-fonts-extra-doc:
texlive-fonts-extra-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-fonts-extra-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-fonts-recommended-doc:
texlive-fonts-recommended-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-fonts-recommended-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-formats-extra:
texlive-formats-extra depends on tex-common (>= 3); however:
texlive-formats-extra depends on texlive-latex-base (>= 2013.20130512); however:
dpkg: error processing package texlive-formats-extra (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-polish:
texlive-lang-polish depends on texlive-latex-base (>= 2013.20130512); however:
texlive-lang-polish depends on tex-common (>= 3); however:
dpkg: error processing package texlive-lang-polish (--configure):
dpkg: dependency problems prevent configuration of texlive-generic-extra:
texlive-generic-extra depends on tex-common (>= 3); however:
dpkg: error processing package texlive-generic-extra (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-indic:
texlive-lang-indic depends on tex-common (>= 3); however:
dpkg: error processing package texlive-lang-indic (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-spanish:
texlive-lang-spanish depends on tex-common (>= 3); however:
dpkg: error processing package texlive-lang-spanish (--configure):
dpkg: dependency problems prevent configuration of texlive-omega:
texlive-omega depends on texlive-latex-base (>= 2013.20130512); however:
texlive-omega depends on tex-common (>= 3); however:
dpkg: error processing package texlive-omega (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-cyrillic:
texlive-lang-cyrillic depends on tex-common (>= 3); however:
texlive-lang-cyrillic depends on texlive-latex-base (>= 2013.20130512); however:
dpkg: error processing package texlive-lang-cyrillic (--configure):
dpkg: dependency problems prevent configuration of texlive-humanities-doc:
texlive-humanities-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-humanities-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-english:
texlive-lang-english depends on tex-common (>= 3); however:
dpkg: error processing package texlive-lang-english (--configure):
dpkg: dependency problems prevent configuration of fragmaster:
fragmaster depends on texlive-latex-base; however:
fragmaster depends on texlive-latex-recommended; however:
fragmaster depends on texlive-extra-utils; however:
fragmaster depends on texlive-font-utils; however:
dpkg: error processing package fragmaster (--configure):
dpkg: dependency problems prevent configuration of texlive-latex-extra-doc:
texlive-latex-extra-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-latex-extra-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-publishers-doc:
texlive-publishers-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-publishers-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-lang-european:
texlive-lang-european depends on tex-common (>= 3); however:
dpkg: error processing package texlive-lang-european (--configure):
dpkg: dependency problems prevent configuration of texlive-pictures-doc:
texlive-pictures-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-pictures-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-metapost-doc:
texlive-metapost-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-metapost-doc (--configure):
dpkg: dependency problems prevent configuration of texlive-science-doc:
texlive-science-doc depends on tex-common (>= 3); however:
dpkg: error processing package texlive-science-doc (--configure):
dpkg: too many errors, stopping
These problems never occurred before the update. I tried to remove the latex packages to solve the problem but even for other purposes APT-GET doesn't work.
Is there a way to fix this?
