16
I upgraded to ubuntu 14.04 yesterday. But after restarting PC , this message continues to appear in a black screen after the ubuntu loading screen and don't go away and ubuntu doesn't start I can do nothing about this. what should I do? I tried logging in from other terminals and do asm here but still nothing
This can be overcome by two way.
  1. Add ServerName localhost as the last line in /etc/apache2/apache2.conf file.
  2. Create a file named /etc/apache2/conf-available/servername.conf and add the string ServerName localhost inside and save it. Create a soft link under /etc/apache2/conf-enabled as follows
    ln -s /etc/apache2/conf-available/servername.conf .
    # or
    a2enconf servername
and restart the server.
The string localhost can be replaced with any valid domain name (ie. example.com).
muru
  • 207,228
ccsen
  • 296
Another way of performing the second option suggested by ccsen is the following:
  1. Create a file in /etc/apache2/conf-available/ with any desired name. servername.conf is a suitable option.
  2. Add the following line to the created file: ServerName yourservername. yourservername can be set to anything you want.
  3. Then run the following from a terminal: sudo a2enconf servername (assuming you called the file added to conf-available on step 1 'servername.conf').
  4. Finally, run the following from the terminal: sudo service apache2 reload
Although both methods achieve the same result, I believe this one is cleaner since apache takes care of the symlinks and enabling the configuration.
Vic07
  • 41
A third way is to configure your computer's hosts file:
127.0.0.1       localhost
127.0.1.1       servername.domain.com       servername
HorusKol
  • 1,607
