Please help! All the solutions given to activate blue tooth and Wireless connections in my HP 650 running on Ubuntu 12.04 has not worked. I ve tried updates, codes to turn on, the rfkill options, etc. I just switched from Windows8 to Ubuntu 12.04, and this is not what i bargained for, please help!!! i did -> lspci -nn | grep 0280 and it brought out
02:00.0 Network controller [0280]: Ralink corp. Device [1814:3290]
Bube
it's my first reply!
I own an HP 650. When I purchased it, there was 12.04 LTS installed and the WiFi/Bluetooth card didn't work out of the box. So I followed the instructions available here: http://ubuntuforums.org/showthread.php?t=2104690 Everything worked perfectly afterwards.
Now I've upgraded my PC to 14.04 LTS. Since I did this upgrade I got problems with the WiFi again. I was able to fix them following these instructions: http://www.dailylinuxnews.com/blog/2014/09/install-ralink-rt3290-wifi-driver-in-ubuntu-linuxmint-elementaryos/ The WiFi network is now working perfectly, but the Bluetooth. Since I don't use the Bluetooth, it's not a big issue, but the WiFi/Bluetooth button on my HP 650 is always "switched off" even if I press it many times.
I hope it helps.
