This situation is somewhat complicated!
I use win7 os and I have to work on the Linux server by the SSH client, PuTTY.
Right now I have installed the VirtualBox into the Linux server in means of command line(since I have to install the VB by PuTTY, where there is no GUI). Then I have to install the iso file of ubuntu-14.04 into the VB in means of command line, too. In order to complete it, I downloaded the VirtualBox_usermanual and executed the procedures as the manual says. However, when I enter the command as follows, the green focus just stayed there
[b50039@neptune ubuntu]$ vboxheadless --startvm ubuntu_14_04
Oracle VM VirtualBox Headless Interface 4.3.10
(C) 2008-2014 Oracle Corporation
All rights reserved.
VRDE server is listening on port 5000.
[green focus]
Could anybody help me? Emergency!!!
landroni
  • 6,011
tank
  • 75
Create a VM from command line
We can fully create and control Virtual Box from the command line using VBoxManage. This involves all of the follwing steps nicely outlined in the Virtual Box Manual:
  • Create and register a virtual machine making sure the ostype is correct.
  • Make appropriate machine settings (RAM, VRAM, CPU, network, etc.)
  • Create a virtual hard drive VDI for this machine
  • Add an IDE controller for this drive
  • Add the virtual hard disk VDI to this IDE controller
  • Attach the boot .iso file to the VM
  • run the VM to install from the CD .iso file
  • optionally install the guest additions for shared folders support
You may want to use an RDP viewer to be able to view the machine's outputs.
Export and import an existing VM
We can see that the above involves quite a lot of single steps to define and set up our virtual machines. In case we are not so familiar with Virtual Box it may be much easier to create, set up, and test a virtual machine on a computer with a graphical interface, export the running and tested VM to then just import the virtual machine on our remote computer:
Takkat
  • 144,580
This is a link to a tutorial
http://www.howopensource.com/2011/06/how-to-use-virtualbox-in-terminal-commandline/
This is a list of Virtual Box commands
http://www.virtualbox.org/manual/ch08.html#idp55479184
ubuntu1up
  • 164
