I recently updated my computer to Ubuntu 14.04, and I really liked and enjoyed all new features, however within an hour or two, my enjoyment ended. I soon learned that the ADT bundle would crash unexpectedly and all of the time. It doesn't say it crashed. It just randomly exits and then I'm left set back a couple of minutes, which is very inconvenient when coding android apps. Especially given the fact that it 'crashes' after only using it for a couple of minutes.
Is this a common problem? Is this unheard of? Is there a known solution for this?
Any help is appreciated.
Thanks.
EDIT
I decided to run ADT from the terminal to see what output was there when it 'crashes' and so here it is.
No bp log location saved, using default.
[000:000] Cpu: 6.23.10, x2, 2668Mhz, 1968MB
[000:000] Computer model: Not available
[000:000] Browser XEmbed support present: 1
[000:000] Browser toolkit is Gtk2.
[000:000] Using Gtk2 toolkit
[000:397] No bp log location saved, using default.
[000:397] Cpu: 6.23.10, x2, 2668Mhz, 1968MB
[000:397] Computer model: Not available
[000:397] Browser XEmbed support present: 1
[000:397] Browser toolkit is Gtk2.
[000:397] Using Gtk2 toolkit
[000:334] No bp log location saved, using default.
[000:334] Cpu: 6.23.10, x2, 2668Mhz, 1968MB
[000:334] Computer model: Not available
Segmentation fault (core dumped)
So I need a bp log? I don't know that is. Hope this bit helps.
Avinash Raj
  • 80,446
KodyVanRy
  • 160
I had the same thing, but an update fixed it for me. Just doing a regular update check says you are up to date, you need to do it through add new software. Read this
https://stackoverflow.com/questions/22513524/error-message-this-android-sdk-requires-android-developer-toolkit-version-22-6
It sorted me out fine.
FatIgor
  • 36
