I had an issue with my laptop in which whenever used Ubuntu connected to wifi, every other device on the same connection would slow to an unusable place. I researched and found someone else had this issue, and the solution there was to run the following:
sudo sh -c "echo 'blacklist wl' >> /etc/modprobe.d/broadcomm-blacklist.conf
sudo sh -c "echo 'brcmsmac' >> /etc/modprobe.d/broadcomm.conf
Being dumb, I did that without fully understanding the consequences/what I was doing, and now my laptop cannot detect wifi connections at all. I suppose I have disabled my driver, though I have no idea how to get it working again.
After the fact, I noticed someone in the comments of the post I mention above warns against this very thing happening --> my fault! Any help is appreciated.
You've added blacklist wl to /etc/modprobe.d/broadcomm-blacklist.conf and brcmsmac to /etc/modprobe.d/broadcomm.conf.
To revert your changes, just remove the lines you've added from the files using sudo nano /etc/modprobe.d/broadcomm-blacklist.conf and sudo nano /etc/modprobe.d/broadcomm.conf.
sudo nano will open a text editor (nano) as su (superuser/admin). Remove the lines you've added (navigate using your cursor keys), and hit CTRL + X, enter, Y and enter again to save.
Also, are you sure it's "broadcomm" and not "broadcom"?
