Has anybody been able to install the icaclient on Ubuntu/Kubuntu x64 successfully? Please respond with steps.
Greatly appreciated.
nymg
Just download the *.deb file from here. Here is how to install. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
apt-get install lib32z1 lib32asound2
to Once that is done, navigate where you've downloaded the file, most likely the Downloads folder, and run the command below:
dpkg -i icaclient_13.0.0.256735_amd64.deb
You can download lib32asound2 from here. Once downloaded, you can install using sudo dpkg -i ib32asound2_1.0.25-4ubuntu4_amd64.deb, or use Gdebi,sudo apt-get install gdebi`
Mitch
  • 109,787
I got it installed using these commands:
sudo sudo apt-get install libasound2:i386
sudo dpkg -i --ignore-depends=ia32-libs,lib32asound2 icaclient_13.0.0.256735_amd64.deb
sudo apt-get install -f
The issue is that lib32asound2 is replaced by libasound2:i386 and ia32-libs is split up in several libfoo:i386 packages (which will be installed automatically). Telling dpkg to ignore these two packages was successful for me.
just follow the steps in Ubuntu Help site.
1- You basically need to download the package from here:
https://www.citrix.com/downloads/citrix-receiver/linux/receiver-for-linux-130.html
2- Install dependencies
sudo apt-get install libmotif4:i386 nspluginwrapper lib32z1 libc6-i386 libxp6:i386 libxpm4:i386 libasound2:i386
3- Make some changes to the package
cd ~/Downloads
mkdir ica_temp
dpkg-deb -x icaclient_13.0.0.256735_amd64.deb ica_temp
dpkg-deb --control icaclient_13.0.0.256735_amd64.deb ica_temp/DEBIAN
Edit the control file
sudo gedit ica_temp/DEBIAN/control
Change the line that starts with depends to:
Depends: libc6-i386 (>= 2.7-1), lib32z1, nspluginwrapper
Edit the post inst script
sudo gedit ica_temp/DEBIAN/postinst
Change line that says "echo $Arch|grep "i[0-9]86" >/dev/null" to
echo $Arch|grep -E "i[0-9]86|x86_64" >/dev/null
Repackage this modified version:
dpkg -b ica_temp icaclient-modified.deb
4- Install modified package
Double click the icaclient-modified.deb or use dpkg -i
5- Copy certificates
sudo ln -s /usr/share/ca-certificates/mozilla/* /opt/Citrix/ICAClient/keystore/cacerts/
sudo c_rehash /opt/Citrix/ICAClient/keystore/cacerts
6- Configure remote drive access
/opt/Citrix/ICAClient/util/configmgr &
Done.
I did not come up with this solution. It is what is in Ubuntu Help site and it worked for me. My only problem is I can not move around Citrix Windows...
