Trying to compile even the simplest (int main(){}) program with -m32 on a 64-bit system fails:
$ gcc -m32 test.c
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.8/libgcc.a when searching for -lgcc
/usr/bin/ld: cannot find -lgcc
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.8/libgcc_s.so when searching for -lgcc_s
/usr/bin/ld: cannot find -lgcc_s
collect2: error: ld returned 1 exit status
It seems to be still erroneously searching in the wrong directories when -m32 is specified.
libgcc-4.8-dev:i386 is installed and I've verified that the 32-bit libraries are located in /usr/lib/gcc/i686-linux-gnu/4.8/.
I've tried setting and exporting LD_INCLUDE_PATH and LD_LIBRARY_PATH to no avail.
