I am looking for a method built-in to ubuntu that will allow me to run a script or program or whatever for a fixed period of time.
I found a program that does this in a way I like, but the package is unavailable for Ubuntu. In any case, I was hoping for something built-in.
The only thing i can think of is to get the current time and set a cron job 30 minutes from 'now' that will kill the program. I was hoping there was a way to do this without setting up a script, but if I need to - it wont be the end of the world. After the 30 minute interval I would like to put my laptop in a sleep mode, but this can be separate from the timer thing.
Thanks in advance.
Braiam
  • 69,112
Teque5
  • 299
Why not use /usr/bin/timeout?
$ timeout --help
Usage: timeout [OPTION] DURATION COMMAND [ARG]...
  or:  timeout [OPTION]
Start COMMAND, and kill it if still running after DURATION.
waltinator
  • 37,856
14
I've just wrote the following and it seems to work:
ping google.com& PID=$!; sleep 3; kill $PID
Of course you should substitute ping with the command you want to run and 3 with a timeout in seconds. Let me know if you need a more detailed explanation on how it works.
Eliah Kagan
  • 119,640
Adam Byrtek
  • 9,861
A simple (and not much tested) version of hatimerun:
#!/bin/sh
help(){
    echo "Usage"  >&2
    echo "  $0 -t TIME COMMAND" >&2
    exit 1
TEMP=`getopt -o t: -n "$0" -- "$@"`
if [ $? != 0 ] ; then
    help
fi
eval set -- "$TEMP"
while true ; do
    case "$1" in
    -t) timeout=$2; shift  2;;
    --) shift; break;;
    esac
done
if [ -z "$timeout" ]; then
 help
fi
cmd="$*"
$cmd&
echo "kill $!" | at now+$timeout
See the manpage of at for how to specify the time. Like with at the minimum time resolution is 1 minute.
Another way is to use upstart instead of this script.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Using Perl:
perl -e "alarm 5; exec @ARGV" systemctl list-timers
Using timelimit command:
sudo apt install timelimit
timelimit -t5 node app.js
Using timeout command:
timeout -sHUP time command
