After installing Sublime Text 3 on Ubuntu 14.04 by coping the extracted files to /opt, I tried running Sublime Text using ./sublime_text.
However it is giving an error No such file or directory when though ls tells us that it exists! What's going on?
x@x-ubuntu:/opt/sublime_text_3$ ls -l
total 11660
-rw-rw-r-- 1 x x    4696 Dec 16 22:28 changelog.txt
-rwxrwxr-x 1 x x  171056 Dec 16 22:28 crash_reporter
drwxrwxr-x 7 x x    4096 Dec 16 22:28 Icon
drwxrwxr-x 2 x x    4096 Dec 16 22:28 Packages
-rwxrwxr-x 1 x x 4172952 Dec 16 22:28 plugin_host
-rw-rw-r-- 1 x x 2582934 Dec 16 22:28 python3.3.zip
-rw-rw-r-- 1 x x   18883 Dec 16 22:28 sublime_plugin.py
-rw-rw-r-- 1 x x   30672 Dec 16 22:28 sublime.py
-rwxrwxrwx 1 x x 4932736 Dec 21 21:57 sublime_text
-rw-rw-r-- 1 x x     532 Dec 16 22:28 sublime_text.desktop
x@x-ubuntu:/opt/sublime_text_3$ ./sublime_text
bash: ./sublime_text: No such file or directory
Nyxynyx
  • 1,163
  • 16
  • 29
You are getting this error because you are trying to run a 32-bit binary on a 64-bit system. If you download the proper package for your system, it should work. If you don't know if your computer is 32-bit or 64-bit, try running
getconf LONG_BIT
(actually this checks if you're running 32-bit or 64-bit Ubuntu, to actually check if your hardware is 32-bit or 64-bit run:
grep -o -w 'lm' /proc/cpuinfo | sort u
and if one of the flags listed is 'lm' you have a 64-bit processor.)
