I got 'suspend' working after and update from Ubuntu 12.04 LTS to 14.04 LTS ( Sony Vaio VPCEB1E0E ).
I had previously used the script below on my Ubuntu 12.04 LTS: [source http://ubuntuforums.org/showthread.php?t=1978290&p=11958911#post11958911]
#!/bin/sh
#inspired by http://art.ubuntuforums.org/showpost.php?p=9744970&postcount=19
#...and http://thecodecentral.com/2011/01/18/fix-ubuntu-10-10-suspendhibernate-not-working-bug
# tidied by tqzzaa :)
VERSION=1.1
DEV_LIST=/tmp/usb-dev-list
DRIVERS_DIR=/sys/bus/pci/drivers
DRIVERS="uhci_hcd xhci_hcd"
HEX="[[:xdigit:]]"
MAX_BIND_ATTEMPTS=2
BIND_WAIT=0.1
unbindDev() {
echo -n > $DEV_LIST 2>/dev/null
for driver in $DRIVERS; do
DDIR=$DRIVERS_DIR/${driver}
for dev in `ls $DDIR 2>/dev/null | egrep "^$HEX+:$HEX+:$HEX"`; do
echo -n "$dev" > $DDIR/unbind
echo "$driver $dev" >> $DEV_LIST
done
done
bindDev() {
if [ -s $DEV_LIST ]; then
while read driver dev; do
DDIR=$DRIVERS_DIR/${driver}_hcd
while [ $((MAX_BIND_ATTEMPTS)) -gt 0 ]; do
echo -n "$dev" > $DDIR/bind
if [ ! -L "$DDIR/$dev" ]; then
sleep $BIND_WAIT
else
break
fi
MAX_BIND_ATTEMPTS=$((MAX_BIND_ATTEMPTS-1))
done
done < $DEV_LIST
fi
rm $DEV_LIST 2>/dev/null
case "$1" in
hibernate|suspend) unbindDev;;
resume|thaw) bindDev;;
esac
On Ubuntu 14.04 LTS, I changed the 'DRIVERS' line from:
DRIVERS="ehci xhci"
to:
DRIVERS="uhci_hcd xhci_hcd" as was the case in the '/sys/bus/pci/drivers' directory.
The next thing I did was to edit the file '/etc/default/grub' (as root), changing the GRUB_CMDLINE_LINUX="" line to GRUB_CMDLINE_LINUX="acpi_sleep=nonvs".
Then running sudo update-grub.
[source Suspend fails (reboot on resume) and no hibernate option ]
These above set of steps did the trick for me.
Hope it helps.
