when I boot ubuntu 14.04 off a usb/DVD to install it wont recognize windows 8.1 and only says " erase disk and install ubuntu ". this is the ubuntu that will work with my laptop. i do not want to get rid of windows 8 and the recovery partition because it will be like throwing $200 down the drain.
Make sure to partition the drive before you install Ubuntu. I unfortunately made the mistake once and wiped my entire hard drive. I highly recommend from personal experience that you get gparted or use the built in partitioner in the Ubuntu install usb to partition at least 15GB for Ubuntu. Do a Google search for "Dual boot Ubuntu alongside Windows" to find explanations more in-depth than I could tell you. Here is a good guide on how to dual boot Ubuntu alongside Windows. http://www.everydaylinuxuser.com/2013/09/install-ubuntu-linux-alongside-windows.html Hope it helps!
- 36
Its better to create a new separate partition and install ubuntu in that partition
you can install in seperate partition by selecting "something else" during installation and selecting your new partition where you want to install Ubuntu
- 5,213
