57
I tried to install Teamviewer 9 on Ubuntu 14.04, unsuccessfully.
I've downloaded the following extra(Raring) packages:
http://archive.ubuntu.com/ubuntu/pool/universe/i/ia32-libs/ia32-libs-multiarch_20090808ubuntu36_i386.deb
http://archive.ubuntu.com/ubuntu/pool/universe/i/ia32-libs/ia32-libs_20090808ubuntu36_amd64.deb
http://archive.ubuntu.com/ubuntu/pool/main/a/alsa-lib/libasound2_1.0.25-4ubuntu3.1_i386.deb
http://archive.ubuntu.com/ubuntu/pool/main/a/alsa-lib/libasound2_1.0.25-4ubuntu3.1_amd64.deb
http://archive.ubuntu.com/ubuntu/pool/main/a/alsa-lib/lib32asound2_1.0.25-4ubuntu3.1_amd64.deb
http://www.teamviewer.com/en/download/linux.aspx
But these errors were happened while I was installing the packages (I've also tried install with Ubuntu's Software Center, the same):
$ sudo dpkg -i *.deb
Selecting previously unselected package ia32-libs.
(Reading database ... 254553 files and directories currently installed.)
Preparing to unpack ia32-libs_20090808ubuntu36_amd64.deb ...
Unpacking ia32-libs (20090808ubuntu36) ...
Selecting previously unselected package ia32-libs-multiarch.
Preparing to unpack ia32-libs-multiarch_20090808ubuntu36_i386.deb ...
Unpacking ia32-libs-multiarch (20090808ubuntu36) ...
Selecting previously unselected package lib32asound2.
Preparing to unpack lib32asound2_1.0.25-4ubuntu3.1_amd64.deb ...
Unpacking lib32asound2 (1.0.25-4ubuntu3.1) ...
dpkg: warning: downgrading libasound2:amd64 from 1.0.27.2-3ubuntu7 to 1.0.25-4ubuntu3.1
Preparing to unpack libasound2_1.0.25-4ubuntu3.1_amd64.deb ...
De-configuring libasound2:i386 (1.0.27.2-3ubuntu7) ...
Unpacking libasound2:amd64 (1.0.25-4ubuntu3.1) over (1.0.27.2-3ubuntu7) ...
Replaced by files in installed package libasound2-data (1.0.27.2-3ubuntu7) ...
dpkg: warning: downgrading libasound2:i386 from 1.0.27.2-3ubuntu7 to 1.0.25-4ubuntu3.1
Preparing to unpack libasound2_1.0.25-4ubuntu3.1_i386.deb ...
Unpacking libasound2:i386 (1.0.25-4ubuntu3.1) over (1.0.27.2-3ubuntu7) ...
Selecting previously unselected package teamviewer.
Preparing to unpack teamviewer_linux_x64.deb ...
Unpacking teamviewer (9.0.27891) ...
More than one copy of package libasound2:i386 has been unpacked
 in this run !  Only configuring it once.
dpkg: dependency problems prevent configuration of ia32-libs-multiarch:
 ia32-libs-multiarch depends on bluez-alsa; however:
  Package bluez-alsa:i386 is not installed.
 ia32-libs-multiarch depends on libgettextpo0; however:
  Package libgettextpo0 is not installed.
 ia32-libs-multiarch depends on gstreamer0.10-plugins-good; however:
  Package gstreamer0.10-plugins-good:i386 is not installed.
 ia32-libs-multiarch depends on gtk2-engines; however:
  Package gtk2-engines is not installed.
 ia32-libs-multiarch depends on gtk2-engines-murrine; however:
  Package gtk2-engines-murrine is not installed.
 ia32-libs-multiarch depends on gtk2-engines-pixbuf; however:
  Package gtk2-engines-pixbuf is not installed.
 ia32-libs-multiarch depends on gtk2-engines-oxygen; however:
  Package gtk2-engines-oxygen is not installed.
 ia32-libs-multiarch depends on ibus-gtk; however:
  Package ibus-gtk is not installed.
 ia32-libs-multiarch depends on libaio1; however:
  Package libaio1:i386 is not installed.
dpkg: error processing package ia32-libs-multiarch (--install):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libasound2:amd64:
 libasound2-data (1.0.27.2-3ubuntu7) breaks libasound2 (<< 1.0.27-4) and is installed.
  Version of libasound2:amd64 to be configured is 1.0.25-4ubuntu3.1.
dpkg: error processing package libasound2:amd64 (--install):
dpkg: dependency problems prevent configuration of libasound2:i386:
  Version of libasound2:i386 to be configured is 1.0.25-4ubuntu3.1.
dpkg: error processing package libasound2:i386 (--install):
dpkg: dependency problems prevent configuration of ia32-libs:
 ia32-libs depends on ia32-libs-multiarch; however:
  Package ia32-libs-multiarch is not configured yet.
dpkg: error processing package ia32-libs (--install):
dpkg: dependency problems prevent configuration of lib32asound2:
 lib32asound2 depends on libasound2 (= 1.0.25-4ubuntu3.1); however:
  Package libasound2:amd64 is not configured yet.
dpkg: error processing package lib32asound2 (--install):
dpkg: dependency problems prevent configuration of teamviewer:
 teamviewer depends on lib32asound2; however:
  Package lib32asound2 is not configured yet.
 teamviewer depends on ia32-libs; however:
  Package ia32-libs is not configured yet.
dpkg: error processing package teamviewer (--install):
 ia32-libs-multiarch
 libasound2:amd64
 libasound2:i386
 ia32-libs
 lib32asound2
 teamviewer
Do someone know how to install the Teamviewer on 14.04?
Braiam
  • 69,112
antivirtel
  • 3,685
As of Ubuntu 11.10, there is no longer an ia32-libs package. Because of this, older x64 packages (such as the x64 version distributed on their site) will no longer be able to install.
TeamViewer has since removed the x64-only download, and they only offer the i386 version.
To install TeamViewer now, it's as simple as visiting the official download page, clicking the "Download" button, and then running the downloaded .deb file.
If you want to use the terminal for this operation, that's still doable:
  1. Grab the TeamViewer debfile:
     wget https://download.teamviewer.com/download/teamviewer_i386.deb
  2. Install the downloaded DEB file:
     sudo dpkg -i teamviewer_i386.deb
  3. If DPKG throws any errors, fix any dependency issues to make sure everything works fine:
     sudo apt update && sudo apt -f install
TeamViewer will now be ready for use and will be present in your menu.
Kaz Wolfe
  • 34,680
Make sure you have wine installed, just like the answer in the link provided by @B. Roland. Wine is needed, because TeamViewer uses some.dll libraries provided by wine.
antivirtel
  • 3,685
oscarMg
  • 19
