10
Since updating to Ubuntu 14.04 I've started getting this error message when running GNUcash. GNUcash says it has nothing to do with them and they suggested asking Ubuntu for help.
So can anyone help with this message:
Gtk-Message: Failed to load module "overlay-scrollbar"
Gtk-Message: Failed to load module "unity-gtk-module"
(npviewer.bin:18843): Gtk-WARNING **: Unable to locate theme engine in module_path: "murrine",
There is more of it, but it just repeats the same lines over and over again.
I've also found these error messages which might help someone find me a cure!
peter@ubuntu:~$ strace gedit 2>&1 | grep can
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/3.0.0/x86_64-pc-linux-gnu/modules/libcanberra-gtk-module.so", F_OK) = -1 ENOENT (No such file or directory)
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/3.0.0/x86_64-pc-linux-gnu/modules/libcanberra-gtk-module.la", F_OK) = -1 ENOENT (No such file or directory)
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/3.0.0/modules/libcanberra-gtk-module.so", F_OK) = -1 ENOENT (No such file or directory)
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/3.0.0/modules/libcanberra-gtk-module.la", F_OK) = -1 ENOENT (No such file or directory)
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/x86_64-pc-linux-gnu/modules/libcanberra-gtk-module.so", F_OK) = -1 ENOENT (No such file or directory)
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/x86_64-pc-linux-gnu/modules/libcanberra-gtk-module.la", F_OK) = -1 ENOENT (No such file or directory)
access("/usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libcanberra-gtk-module.so", F_OK) = 0
stat("/usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libcanberra-gtk-module.so", {st_mode=S_IFREG|0644, st_size=23112, ...}) = 0
open("/usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libcanberra-gtk-module.so", O_RDONLY|O_CLOEXEC) = 10
open("/usr/lib/x86_64-linux-gnu/gedit/libcanberra-gtk3.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libcanberra-gtk3.so.0", O_RDONLY|O_CLOEXEC) = 10
open("/usr/lib/x86_64-linux-gnu/gedit/libcanberra.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libcanberra.so.0", O_RDONLY|O_CLOEXEC) = 10
writev(8, [{"\22\0\17\0\205\0@\4p\1\0\0\33\1\0\0\10\0\0\0!\0\0\0/com/can"..., 176}, {NULL, 0}, {"", 0}], 3) = 176
open("/usr/lib/x86_64-linux-gnu/libcanberra-0.30/libcanberra-pulse.la", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libcanberra-0.30/libcanberra-pulse.so", O_RDONLY|O_CLOEXEC) = 15
peter@ubuntu:~$
karel
  • 122,292
  • 133
  • 301
  • 332
Peter
  • 801
The Message lines mean you are missing the overlay-scrollbar-gtk2 and unity-gtk2-module packages.
The WARNING is because you are apparently missing the gtk2-engines-murrine package.
dobey
  • 41,650
