My Realtek RTL8187 USB wifi card is having trouble keeping a connection for more than a few seconds, while on the same machine under Windows 7 it has no problem. When I make the connection, I have a few seconds of full-bandwidth communication, followed by the connection completely failing to send or receive packets (the card usually makes a soft sound from the antenna, under both OSs, which cuts out, along with actual networking capabilities on Ubuntu). Network manager and WICD both report the card as still connected, with reasonable signal levels (around -40dBi, which is not a problematic level for this card on Windows). The loss of communication happens replicably and reliably, although occasionally I manage to transmit and receive a few stray packets. The indicator light on the card flickers constantly and abnormally quickly after the connection is lost.
I've tried to connect to both my WPA2 and (with consent) a neighbor's WEP access points (mine being Netgear, and theirs being Belkin), with the same result of losing the link after roughly one second. Ethernet is un-affected. This card is being used with the rtl8187 kernel module. I'm using a clean, fresh installation of Trusty x64. This did not occur on the live CD.
dmesg | tail -n 25 for the WEP network:
hexafraction@ubuntu-lapdesk:~/Downloads$ dmesg | tail -n 25
[16505.923287] wlan1: associated
[16505.923370] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[16505.943812] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[16535.278129] atl1c 0000:01:00.0: atl1c: eth0 NIC Link is Down
[16540.067784] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[16543.677051] wlan1: deauthenticating from [PREVIOUS AP MAC] by local choice (reason=3)
[16543.737566] cfg80211: Calling CRDA to update world regulatory domain
[16543.747499] cfg80211: World regulatory domain updated:
[16543.747510] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[16543.747518] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[16543.747524] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[16543.747529] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[16543.747534] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[16543.747539] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[16546.240014] wlan1: authenticate with [AP MAC]
[16546.298661] wlan1: send auth to [AP MAC] (try 1/3)
[16546.300412] wlan1: authenticated
[16546.300741] rtl8187 1-3:1.0 wlan1: disabling HT/VHT due to WEP/TKIP use
[16546.300747] rtl8187 1-3:1.0 wlan1: disabling HT as WMM/QoS is not supported by the AP
[16546.300751] rtl8187 1-3:1.0 wlan1: disabling VHT as WMM/QoS is not supported by the AP
[16546.304473] wlan1: associate with [AP MAC] (try 1/3)
[16546.307090] wlan1: RX AssocResp from [AP MAC] (capab=0x431 status=0 aid=2)
[16546.307946] wlan1: associated
[16546.307992] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[16546.308625] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
lsmod:
Module Size Used by
rtl8187 64909 0
mac80211 626489 1 rtl8187
cfg80211 484040 2 mac80211,rtl8187
nls_utf8 12557 0
isofs 39835 0
ctr 13049 0
ccm 17773 0
rfcomm 69160 0
bnep 19624 2
bluetooth 395423 10 bnep,rfcomm
hid_generic 12548 0
joydev 17381 0
uvcvideo 80885 0
videobuf2_vmalloc 13216 1 uvcvideo
videobuf2_memops 13362 1 videobuf2_vmalloc
videobuf2_core 40664 1 uvcvideo
videodev 134688 2 uvcvideo,videobuf2_core
usbhid 52616 0
eeprom_93cx6 13344 1 rtl8187
arc4 12608 2
hid 106148 2 hid_generic,usbhid
kvm_amd 59987 0
kvm 451511 1 kvm_amd
radeon 1514165 3
psmouse 102222 0
k10temp 13126 0
toshiba_acpi 22901 0
sparse_keymap 13948 1 toshiba_acpi
serio_raw 13462 0
wmi 19177 1 toshiba_acpi
snd_hda_codec_conexant 57441 1
snd_hda_codec_hdmi 46207 1
snd_hda_intel 52355 5
snd_hda_codec 192906 3 snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_hda_intel
ttm 85115 1 radeon
snd_hwdep 13602 1 snd_hda_codec
snd_pcm 102099 3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel
snd_page_alloc 18710 2 snd_pcm,snd_hda_intel
snd_seq_midi 13324 0
snd_seq_midi_event 14899 1 snd_seq_midi
snd_rawmidi 30144 1 snd_seq_midi
snd_seq 61560 2 snd_seq_midi_event,snd_seq_midi
snd_seq_device 14497 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 29482 2 snd_pcm,snd_seq
drm_kms_helper 52758 1 radeon
snd 69238 21 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_conexant,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
soundcore 12680 1 snd
drm 302817 5 ttm,drm_kms_helper,radeon
video 19476 0
i2c_piix4 22155 0
i2c_algo_bit 13413 1 radeon
mac_hid 13205 0
parport_pc 32701 0
ppdev 17671 0
lp 17759 0
parport 42348 3 lp,ppdev,parport_pc
ahci 25819 2
atl1c 46086 0
libahci 32168 1 ahci
I'm at a loss here, as I've tried reboots, wicd, and network-manager. The card itself is fine on Windows 7 (as I still dual-boot and can test it). I've removed network-manager before using wicd, and vice-versa, as well as having both installed. My suspicion is that some service or background program is causing the card to channel-hop, but I am not sure how to check whether that is happening, or which service is causing it. However, the hard-block issues seen on the live CD are not happening.
Due to my not having been able to check this on previous versions due to GPU incompatibility making Ubuntu unusable, I have no evidence that this is a bug introduced in Trusty.
Edit: sudo iwconfig wlan1 when not connected:
wlan1 IEEE 802.11bg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
sudo iwconfig wlan1 when connected to my WPA2 net:
wlan1 IEEE 802.11bg ESSID:"XXXXXXXXXX"
Mode:Managed Frequency:2.462 GHz Access Point: XX:XX:XX:XX:XX:XX
Bit Rate=54 Mb/s Tx-Power=20 dBm
Encryption key:off
Link Quality=39/70 Signal level=-71 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:2 Missed beacon:0
sudo iwconfig wlan1 for WEP:
Mode:Managed Frequency:2.437 GHz Access Point: XX:XX:XX:XX:XX:XX
Bit Rate=11 Mb/s Tx-Power=20 dBm
Encryption key:15A4-A159-AF
Link Quality=47/70 Signal level=-63 dBm
Tx excessive retries:27 Invalid misc:33 Missed beacon:0
I know for a fact that Windows experiences higher signal levels, both in terms of the dBm scale, and in terms of reported percentage connection quality.
