50
dmesg shows the line
systemd-hostnamed[3964]: Warning: nss-myhostname is not installed.
Changing the local hostname might make it unresolveable. Please install nss-myhostname!
But
sudo apt-get install nss-myhostname
says
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
E: Paket nss-myhostname kann nicht gefunden werden.
...meaning "nss-myhostname not found".
Why? Do I have to react on the dmesg message?
There is a confirmed bug logged against systemd-hostnamed saying;
Since nss-myhostname was rejected as being the right approach in https://bugs.launchpad.net/ubuntu/+source/libnss-myhostname/+bug/1162478/comments/6 , we should not print the warning message in the LTS release, even if hostnamed doesn't currently modify /etc/hosts.
Can we please patch this warning out to prevent users from thinking something is wrong on their system and leading them to install libnss-myhostname?.
Even though it may avoid the warning, you may not want to install libnss-myhostname for that purpose only.
Any body seeing the message
 systemd-hostnamed
[16495]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
must read this https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1277608 this https://bugs.launchpad.net/ubuntu/+source/libnss-myhostname/+bug/1162478/comments/6 before installing the nss-myhostname package.
geezanansa
  • 1,610
yoyoma2
  • 1,277
27
From here:
nss-myhostname is a plugin for the GNU Name Service Switch (NSS) functionality of the GNU C Library (glibc) providing hostname resolution for the locally configured system hostname as returned by gethostname(2) There are two possible solutions:
  • You may have not (or incorrectely) configured your hostname in /etc/hosts. Correcting that may resolve this.
  • Another way, as the warning suggests, is to install nss-myhostname, which is referred to in debian as libnss-myhostname. This is only a workaround, not the suggested solution to the relevant bug. Install using:
    sudo apt-get install libnss-myhostname
Source: 13.04 dmesg: Warning: nss-myhostname is not installed
flickerfly
  • 7,509
jobin
  • 28,567
I doubt you will want to install those libraries. Seen as it's nothing more than a nuisance you can simply silence the message.
Create a new config file in /etc/rsyslog.d/ and tell the message to be dropped:
$ sudo nano /etc/rsyslog.d/20-systemd-hostnamed.conf
Add the following single line:
:msg, contains, "Warning: nss-myhostname is not installed." stop
Save and close, and restart the daemon:
$ sudo service rsyslog restart
Job done. You can make sure that the messages are being dropped by intentionally trying to spam your syslog:
$ logger -t TEST "Warning: nss-myhostname is not installed."
The message should be silently dropped.
Ken Sharp
  • 1,086
-1
I was having the same issue.
Not a long-term solution by any means - but one that suited me - was to remove the old host names attached to my localhost in /etc/hosts/ as these are no longer used.
The message is no longer served.
edlee
  • 189
