After the upgrade of my laptop to 14.04, I have problems to enable the Wi-Fi.
My Wireless card is
01:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
I had tried the "tricks" from here and here but nothing worked. The proposed solutions applied for 12.04 so I believe that's why I am not able to enable the Wireless.
I tried also the below:
sudo rfkill unblock all
sudo rfkill list
but with no luck..
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
1: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
I tried also with the Super+F12 and/or Fn+F12 but the message is the same in "Network manager":
Wi-Fi is disabled by hardware switch
From all the above it seems that the hardware is blocked (somehow). From bios I also enabled whatever related with "Wi-Fi/WLAN" but again no luck.
The result of lsmod is:
Module                  Size  Used by
snd_hda_codec_hdmi     46207  1
snd_hda_codec_realtek    61438  1
joydev                 17381  0
ath3k                  13318  0
btusb                  32412  0
intel_rapl             18773  0
coretemp               13435  0
kvm_intel             143060  0
snd_hda_intel          52355  3
snd_hda_codec         192906  3 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_intel
rfcomm                 69160  8
snd_hwdep              13602  1 snd_hda_codec
bnep                   19624  2
snd_pcm               102099  3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel
bluetooth             395423  23 bnep,ath3k,btusb,rfcomm
uvcvideo               80885  0
rts5139               335409  0
kvm                   451511  1 kvm_intel
videobuf2_vmalloc      13216  1 uvcvideo
snd_page_alloc         18710  2 snd_pcm,snd_hda_intel
videobuf2_memops       13362  1 videobuf2_vmalloc
videobuf2_core         40664  1 uvcvideo
videodev              134688  2 uvcvideo,videobuf2_core
arc4                   12608  2
crct10dif_pclmul       14289  0
crc32_pclmul           13113  0
snd_seq_midi           13324  0
snd_seq_midi_event     14899  1 snd_seq_midi
ghash_clmulni_intel    13259  0
ath9k                 164164  0
cryptd                 20359  1 ghash_clmulni_intel
ath9k_common           13551  1 ath9k
snd_rawmidi            30144  1 snd_seq_midi
ath9k_hw              453856  2 ath9k_common,ath9k
snd_seq                61560  2 snd_seq_midi_event,snd_seq_midi
ath                    28698  3 ath9k_common,ath9k,ath9k_hw
snd_seq_device         14497  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              29482  2 snd_pcm,snd_seq
mac80211              626489  1 ath9k
psmouse               102222  0
serio_raw              13462  0
i915                  783485  2
snd                    69238  17 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
drm_kms_helper         52758  1 i915
cfg80211              484040  3 ath,ath9k,mac80211
drm                   302817  3 i915,drm_kms_helper
soundcore              12680  1 snd
i2c_algo_bit           13413  1 i915
toshiba_acpi           22901  0
sparse_keymap          13948  1 toshiba_acpi
toshiba_bluetooth      12852  0
video                  19476  1 i915
wmi                    19177  1 toshiba_acpi
parport_pc             32701  0
mac_hid                13205  0
ppdev                  17671  0
lp                     17759  0
parport                42348  3 lp,ppdev,parport_pc
nls_iso8859_1          12713  1
hid_generic            12548  0
usbhid                 52616  0
hid                   106148  2 hid_generic,usbhid
r8169                  67581  0
mii                    13934  1 r8169
ahci                   25819  4
libahci                32168  1 ahci
Does anyone have an idea what else should be done in order to enable my Wireless card?
Is there any backport software from which i can pull the necessary driver or is already included in linux-kernel?
Thanks in advance!
Pavlos
I had the same problem, found a solution on a forum and it worked for me. I am using a Toshiba Satellite L750 with Qualcomm Atheros AR9585 and my wi-fi was hardware blocked. So I did what was said in that forum. I simply rebooted and immediately I pressed my wi-fi activation keyboard combination (FN+F8) and the led for wi-fi turned on and so my wi-fi was hardware unblocked.
Ragnar
  • 151
I've got the similar problem with ath9k driver.
I solved this problem with a workaround that I found here.
echo "options asus_nb_wmi wapf=4" | sudo tee /etc/modprobe.d/asus_nb_wmi.conf
This command that I've inserted above change the default behavior of ath9k.
After this change I noticed a strange things because network led indicator says that I'm offline, but I can go online through my wireless network card.
I hope this could help you.
Danibix
  • 2,185
