Using Powerbroker instead of likewise
do as steps below
1- download powerbroker frome here
http://download1.beyondtrust.com/Technical-Support/Downloads/PowerBroker-Identity-Services-Open-Edition/?Pass=True
2- run it ,
sudo chmod a+x
run by typing it and hitting enter key
sudo ./pibsfilename.sh
3- join by one of the below commands
sudo domainjoin-cli join domainname.com administrator@domainname.com
or
sudo domainjoin-cli join --disable ssh domainname.com administrator@domainname.com
4- Also, note that you might need to make one minor change to a config file as noted here. Namely, in the file /etc/pam.d/common-session, change the line that reads:
session sufficient pam_lsass.so
to
session [success=ok default=ignore] pam_lsass.so
5- run this command to config, like lwconfig in likewise (run from home folder), use caret ^ for spaces in group names
/opt/pbis/bin/config Requiremembershipof "domainname\\ASecurityGroupFromYourDomain" "domainname\\plus^other^group"
/opt/pbis/bin/config AssumeDefaultDomain true
/opt/pbis/bin/config UserDomainPrefix domainname
6- if you want a username to be sudoer do as follows
sudo nano /etc/sudoers
after root line add the line below
username ALL=(ALL:ALL) ALL
for group use %:
%DOMAINNAME\\Power^Users ALL=(ALL:ALL) ALL
7- and finally edit lightdm configuration file
sudo nano /usr/share/lightdm/lightdm.conf.d/50-unity-greeter.conf
allow-guest=false
greeter-show-remote-login=false
greeter-show-manual-login=true
(60-lightdm-gtk-greeter.conf in Lubuntu 14.04)
8- Reboot
Resources used:
