I have this Acer Aspire V5 notebook, which had problems with wifi before in 13.10 and i had to use the ethernet. sometimes it randomly started working but most of the time it wouldn't. So then i updated and wifi still doesn't work, no matter what i try.
I tried unplugging the cable, replugging it while connecting to wifi and some other combos but it just doesn't connect. it shows that blank wifi symbol everytime. :( please i'm looking for help anything appreciated. oh btw ethernet cable works fine :/ but it's annoying to switch it between my desktop and laptop everyime :P
Avinash Raj
  • 80,446
See if there is a driver available for your chipset. Go to software (software sources) and the tab all the way to the right should say something like "additional Drivers". See if anything is available. Otherwise, give use the output of 'lspci' so we can see what chipset you're using and try to figure things out from there.
lbaile200
  • 586
