13
I'm writing a backup script in which I need to mount a drive in the media bay of my laptop.
I know that I can get the job done by messing with fstab and the mount command. Perhaps that's the easiest way. Anyway, I'm interested in the following:
  1. Initially the media bay drive is unmounted.
  2. I click on the drive in the side-panel in a nautilus window and the drive is mounted.
  3. I can access it at /media/baydrive.
My question:
Is there an easy way of performing step 2 from the command line? I.e., mount the drive to /media/<device name> without messing with fstab.
aioobe
  • 1,616
5 Answers5
13
Try udisks --mount <device name>
To mount by partition label, you can do
udisks --mount /dev/disk/by-label/baydrive
RolandiXor
  • 51,797
The most equivalent (at least for ubuntu 14.4) is
udisksctl mount --block-device /dev/disk/by-label/baydrive
udisksctl unmount --block-device /dev/disk/by-label/baydrive
The difference between udisks and udisksctl is that udisks always mount under /media, while udisksctl mount where nautilus would, which is sometimes /media/${USER}
UmNyobe
  • 161
If you want this to be for your user and not root try this
udisksctl mount -b /dev/sdb2
use the right name of your disk
edwinksl
  • 24,109
automounted drives
/media/username/driveUUID/
nautilus samba mounted drives are found in
/run/user/1000/gvfs/smb-share:server=10.100.4.16,share=share-name/path-to-folder/
or for sftp mounts you can access at
/run/usr/1000/gvfs/sftp\:host\=10.100.4.16/
CRTLBREAK
  • 131
-1
You can alternatively mount the drive, it will then appear at the side panel.. you can right click that shortcut on the side panel and lock it on the launcher.. now you will be able to simply single click that icon to mount the drive without any command, startup script or opening nautilus.
TopGun
