I installed gksudo on Ubuntu 14.04 LTS and when I run nautilus with gksudo nautilus, it asks for password, then gives an error and then crashes
 (nautilus:19688): GLib-GObject-WARNING **: invalid cast from 'GtkMessageDialog' to 'NautilusWindow'
 ERROR:nautilus-window.c:2116:nautilus_window_get_slots: assertion failed: (NAUTILUS_IS_WINDOW (window))
I though sudo nautilus seems to work fine
Update:
Well, the problem has stopped occurring and gksudo nautilus works just fine. And I have absolutely no idea why this happened.
Any insight on what my original problem was and how it got solved is highly appreciated.
rzickler
  • 187
Back.Slash
  • 2,176
Mentioned problem is now fixed in the same nautilus package version 1:3.10.1-0ubuntu8. If you still face this problem in Ubuntu 14.04 then update your nautilus package version from 1:3.10.1-0ubuntu8 to 1:3.10.1-0ubuntu9.
1:3.10.1-0ubuntu9 version of nautilus package is available at trusty-proposed repository. Follow this answer to enable trusty-prosed repository. After that update all the repositories by running sudo apt-get update command and install nautilus 1:3.10.1-0ubuntu9 package by running sudo apt-get install nautilus command on terminal.
Avinash Raj
  • 80,446
