I'm trying to install fglrx manually from the AMD website however it keeps complaining that it's missing the dependency "libc6-amd64".
When I run the fglrx package through gdebi I get this message:
This package is uninstallable
Dependency is not satisfiable: libc6-amd64 (>= 2.9)
Even though it's installed...
dpkg -l | grep libc6
ii  libc6:amd64                                           2.19-0ubuntu6                                       amd64        Embedded GNU C Library: Shared libraries
ii  libc6:i386                                            2.19-0ubuntu6                                       i386         Embedded GNU C Library: Shared libraries
ii  libc6-amd64                                           2.19-0ubuntu6                                       i386         Embedded GNU C Library: 64bit Shared libraries for AMD64
ii  libc6-dbg:amd64                                       2.19-0ubuntu6                                       amd64        Embedded GNU C Library: detached debugging symbols
ii  libc6-dev:amd64                                       2.19-0ubuntu6                                       amd64        Embedded GNU C Library: Development Libraries and Header Files
ii  libc6-i386                                            2.19-0ubuntu6                                       amd64        Embedded GNU C Library: 32-bit shared libraries for AMD64
In the end, I managed to get fglrx to install using the below command which ignored all dependencies:
sudo dpkg -i --force-all fglrx*.deb
Though I was wondering if anyone knows how to fix this since in apt I now get this error:
apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 fglrx : Depends: libc6-amd64 (>= 2.9) but it is not installable
 fglrx-amdcccle : Depends: libc6-amd64 (>= 2.3) but it is not installable
E: Unmet dependencies. Try using -f.
Khronos
  • 123
I find a workaround while searching on google. I recompiled libc6 and its other packages. It fixed unmet dependency problem of Amd's binary Ubuntu package.
First, Add source code repositries on Ubuntu Software Center ( https://help.ubuntu.com/community/Repositories/Ubuntu )
I rebuilt libc6-amd64 Ubuntu package:
sudo apt-get update && sudo apt-get --compile source libc6-amd64
I installed all eglibc (Embedded GNU C Library) packages with overriding problems.
Packages must created under directory that you gave "apt-get --compile source libc6-amd64" command:
sudo dpkg --force-all -i *.deb
Then, give same command to install your Amd Ubuntu packages:
It must install your Amd Ubuntu packages.
If you try to reinstall your Amd Ubuntu Packages, you have to reinstall libc6 and libc6-amd64 ( eglibc ) packages again.
It is my simple solution to fix dependency problem.
There are two ways to fix problem:
a) Patching generated packages https://gist.github.com/dz0ny/b9e3fce83d0c52e16857
b) Generating virtual package libc6-amd64 which lists libc6:amd64 as dependecy
αғsнιη
  • 36,350
dz0ny
