I have a small issue with libc6 package. There is some output:
root@xubuntu:/# aptitude versions libc6
Package libc6:
p   2.17-93ubuntu4  saucy   500
H   2.18-4                  100
root@xubuntu:/# aptitude show libc6
Package: libc6
State: partially installed
Automatically installed: no
Multi-Arch: same
Version: 2.18-4
Priority: required
Section: libs
Maintainer: GNU Libc Maintainers <debian-glibc@lists.debian.org>
Architecture: amd64
Uncompressed Size: 10.5 M
Depends: libgcc1
Suggests: glibc-doc, debconf | debconf-2.0, locales
Conflicts: prelink (<= 0.0.20090311-1), prelink (<= 0.0.20090311-1), tzdata (< 2007k-1), tzdata (< 2007k-1), tzdata-etch, tzdata-etch
Breaks: hurd (< 1:0.5.git20140203-1), hurd (< 1:0.5.git20140203-1), locales (< 2.18), locales (< 2.18), locales-all (< 2.18), locales-all (< 2.18), lsb-core (<=
    3.2-27), lsb-core (<= 3.2-27), nscd (< 2.18), nscd (< 2.18), libc6 (!= 2.18-4)
Replaces: libc6-amd64, libc6-amd64, libc6 (< 2.18-4)
Provides: glibc-2.18-1
Description: Embedded GNU C Library: Shared libraries
 Contains the standard libraries that are used by nearly all programs on the system.     This package includes shared versions of the standard C library and the standard math library, as well as many others.
Homepage: http://www.eglibc.org
root@xubuntu:/# aptitude reinstall libc6
The following packages will be REINSTALLED:
  libc6 libc6:i386
0 packages upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 26 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
E: I wasn't able to locate a file for the libc6 package. This might mean you need to manually fix this package.
E: Internal error: couldn't generate list of packages to download
I suppose I need to uninstall version 2.18-4 without removing dependencies and older package version. So, how to do it?
Everv0id
  • 101
You can use apt-get to install a specific version of the package a long as it is in an archive that apt knows about. From the apt-get manpage:
A specific version of a package can be selected for installation by following the package name with an equals and the version of the package to select. This will cause that version to be located and selected for install. Alternatively a specific distribution can be selected by following the package name with a slash and the version of the distribution or the Archive name (stable, frozen, unstable).
For example, you could do:
sudo apt-get install apache2=2.2.20-1ubuntu1 Note that you may need to do some dependency resolution on your own in this case, but if there are any problems apt-get will tell you what is causing them. On my 11.10 system I would need to do the following to get this to work:
sudo apt-get install apache2=2.2.20-1ubuntu1 \ apache2.2-common=2.2.20-1ubuntu1 \ apache2.2-bin=2.2.20-1ubuntu1 \ apache2-mpm-worker=2.2.20-1ubuntu1'
Original Answer: How to install specific Ubuntu packages, with exact version?
Cody
  • 364
