-1
XnViewMP could be fine but how can I instal it? I can't understand the forums sort of coding. I can't do it.
Seth
  • 59,332
If you like XNView then download the deb package from here. If Ubuntu software center won't let you install it then do a sudo apt-get install gdebi and open the deb file with GDebi.
Another software for image editing is Pinta. You can install it with sudo apt-get install pinta.
After all GIMP is the best solution, but if you do simple adjustments to images those two alternatives are good enough.
Cornelius
  • 9,653
To install XnView, first you need to know if your Ubuntu is 64bit or 32bit, then download the appropriate deb file. This is for 32bit and this for 64bit Ubuntu.
After that, just double click the deb file from nautilus, or if you prefer using terminal, just type
sudo dpkg -i XnViewMP-linux.deb
or
sudo dpkg -i XnViewMP-linux-x64.deb
from the download directory.
pram
  • 960
  • 13
Won't GIMP get your job done ?
It's also available at Ubuntu Software Center.
chrk
  • 175
Use GIMP, type in terminal
sudo apt-get install gimp
Back.Slash
  • 2,176
