11
So I just installed Ubuntu 14.04 tonight and I'm having this weird issue with my mouse and window focus.
I can't seem to click on any Unity Launcher icons. More over I can't click on unfocused windows to bring them to the front. It doesn't work.
I don't know how better to explain this. It is seemingly random when I can click on something inside a window. I can't even click on the "X" button to close or the title bar to move the window around most of the time. What's causing this behaviour?
I really want to start using Ubuntu as my main desktop but I've always had weird issues like this when I would test out a release. In a VM I don't have problems but after a real install I get problems.
Edit: Some more information, my mouse is a USB RAT5 gaming mouse. Not that I think it's the physical mouse that's broke...and the pointer doesn't freeze or anything. I just can't click on anything the majority of the time.
Craig
  • 181
5 Answers5
So I kept looking around and the problem seems to have been the type of mouse I have. I found a thread on the Ubuntu forums by a user with a similar mouse having a problem that sounded like mine. In the thread it was suggested to (create and) edit the /etc/X11/xorg.conf files with the following:
Section "InputClass"
    Identifier "Mouse Remap"
    MatchProduct "Saitek Cyborg R.A.T.5 Mouse"
    MatchDevicePath "/dev/input/event*"
    Option "ButtonMapping" "1 2 3 4 5 6 7 2 9 10 11 12 0 0 0"
EndSection
And then I restarted my computer.
I have RAT5 gaming mouse and the use from the thread has the RAT7 gaming mouse. It has been a day since I implemented the fix and there have been no problems. Didn't bother looking into why it was buggy but I know the above configuration fixed it.
Thread: http://ubuntuforums.org/showthread.php?t=2152976
Craig
  • 181
I found a solution to similar focus problem. A part of it was that mouse focus remained locked to one window but keyboard focus was in another. I fixed it by running:
sudo apt install wmctrl
xfconf-query -c xfwm4 -p /general/click_to_focus -s true
wmctrl -R WindowName
xfconf-query -c xfwm4 -p /general/click_to_focus -s false
Here are the links to original answer and bug report.
ohwell
  • 23
A search for a similar problem brought me here. Left mouse click doesn't work anymore, neither on the mouse itself nor on touch pad. In my case it is a matter of a bluetooth mouse.
My solution was to remove the mouse from the list of paired bluetooth devices (Dash → Bluetooth), switch off the mouse and re-pair it after a reboot.
David
  • 131
I had this on 16.04 with a laptop and a USB mouse connected. USB mouse didn't work. Clicking once on the laptop's touchpad got the mouse's buttons to work again.
simbabque
  • 777
I had this problem with a wireless mouse on an Asus laptop. My touch pad, that I prefer not to use, was actually doing the same.
I tried a bunch of things, but in the end what fixed it was to unplug the usb receiver for my mouse, and plug it back in. Everything back to normal.
Not even a full restart did the same.
