so I installed Ubuntu 14.04 and then installed Netflix-Desktop. When I playback an video the audio plays back just fine, but the video is lagging behind a lot. Had this working on Linux Mint 16 just fine. My best bet is that it has something to do with pulseaudio, again...
System Setup:
Nvidia Geforce 580GTX with driver 331.38 installed
Dual Screen monitors
Asus p8z77-deluxe motherboard
Ask if you need any logs about anything. Thanks!
revint
I solved it. When installing Ubuntu I had to set nomodeset, noapic and nolapic in the grub boot editor. To bypass a system freeze glitch in the open sourced nouveau driver. I guess grub felt like remembering my previous boot settings after installing Ubuntu.
Solution:
From Terminal do
  1. sudo nano /etc/default/grub
  2. Look for this line GRUB_CMDLINE_LINUX="acpi=off noapic nolapic nomodeset"
  3. Replace it with something likeGRUB_CMDLINE_LINUX="acpi=on"
  4. ctrl+o To save and ctrl+x to exit nano
  5. Next we have to update grub with the new settings sudo update-grub
  6. Reboot the system.
Afterwords Netflix-Desktop, among other things, should work.
Also as a reminder you should first install the Nvidia drivers before anything, if you have a 580GTX. Otherwise nouveau will crash on you.
revint
