I'm trying to upgrade from 12.04 to 14.04 and am encountering problems.
I'm working from 12.04. Downloaded the 14.04 iso file. Used the Startup Disc Creator App.
However, when I try to boot from USB, I get a "Boot error" message.
I've tried booting with the USB drive in all 4 USB ports. I've reformatted the USB drive. I've re-downloaded the iso file. Keep getting the same results.
Frustrating because it worked fine when I loaded 12.04 using this same procedure on the same computer (Toshiba Satellite with AMD 64 processor).
Seth
  • 59,332
p-funk
I would perform a MD5 check to make sure the .ISO file you are downloading is good. The procedure is here: https://help.ubuntu.com/community/HowToMD5SUM (do the manual procedure its fast and easy).
The 14.04 MD5 value is here: http://releases.ubuntu.com/trusty/MD5SUMS
I have never installed using a usb, and have aways used a DVD disk. It's really easy if it's an option for you. If using a USB is important to you, take a look here to make sure what you are doing is the same as the 14.04 bootable USB procedure: https://help.ubuntu.com/community/Installation/FromUSBStick
Lastly, make sure that your bios boot order allows your boot device to be the highest in the list; or manually select where to boot from when your PC starts.
If it worked on a 12.04 install, it is a good sign! Just keep digging, you'll get it.
Mike
  • 832
  • 13
  • 24
Got 14.04 on the system without having to re-install using USB stick.
Found this link with instructions on how to upgrade directly from within 12.04.
Here are the steps:
Make sure all updates are installed. Open a terminal screen Type sudo update-manager -d An update window pop-up window should appear with an option at the top to upgrade to 14.04.
Worked perfectly for me.
p-funk
