So, does my 6-yr old Core-2 Duo 32-bit processor system work best with the 32-bit distro, or will the 64 bit version work?
I would recommend reading For better performance should I install 32-bit or 64-bit? and I installed a 64-bit OS in a 32-bit processor
But the truth is, if you do not have the following hardware specs ready, 64 bit is not for you yet:
- CPU is 64 bit capability
- Motherboard that supports 64 bit (It should if the CPU is 64 bit)
- At least 4 GB of RAM. IF you have less than 4 GB it is recommended to stay on 32 bit because 64 bit will not have a optimal performance.
To test this out, simply insert the Live Ubuntu DVD/USB on your computer and see if it runs. If it runs and you see the desktop, then you have a 64 bit capable CPU. If you get a architectural error then you can only use the 32 bit version of Ubuntu.
Another way to check this is to run the lscpu command. Here is what mines look like:
cyrex@cyrex:~$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 60
Stepping: 3
CPU MHz: 800.000
BogoMIPS: 6811.87
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 8192K
NUMA node0 CPU(s): 0-7
If you see the line that says CPU op-mode it shows that it supports 32 bit and 64 bit. The Architecture line shows what Ubuntu arch I am using at the moment, which would be the 64 bit one.
Lastly, I am sure (I might be wrong so please correct me) that all Core 2 Duo are 64 bit capable. I just checked all Core 2 Duo Processors and none of them were 32-bit only. I checked all 2006, 2007 and 2008. So if you could add what model your CPU is, it would help more.
If I am correct, then for your case I recommend 64 bit. You have 4 GB of RAM and a good CPU for Ubuntu 64 bit.
- 216,643
You cannot install a 64-bit Operating System (or any other 64-bit software) on a 32-bit processor (System). While 64-bit processor supports any 32-bit application, reverse is not true. Hence you can run any 32-bit application(i386) on a 64-bit processor/System (amd64) but not the other way around. 64-bit Operating-Systems/Aplications are made specifically only for 64-bit processors.
That leaves you with no choice but to install 32-bit distro/version of Ubuntu IF you have a 32-bit processor.
I remembered Core 2 duo to be 64-bit and Wikipedia page 'Inter Core Family' confirms it
You can also check typing in terminal:
lscpu
and check CPU op-mode entry, if 64-bit is supported then it will be mentioned there,
- 2,176
