Ok so it seems that the key in org.gnome.settings-daemon.plugins.power idle-dim-time is gone in the new Ubuntu version. Since the old method Increase screen idle dim timeout doesn't work anymore are there any other ways to change this?
Homulvas
  • 292
It looks like the setting for idle dim time has changed schemas. Use org.gnome.desktop.session idle-delay:
gsettings set org.gnome.desktop.session idle-delay <value>
For the future, a great way to find a setting is to pipe list-schemas or list-recursively to grep. That's how I figured this one out:
gsettings list-recursively | grep idle
Hope that helped!
ruby
  • 86
this command helped in my case:
gsettings set org.gnome.settings-daemon.plugins.power idle-brightness 180
daniel
Apparently Gnome developers decided that user does not need any way to customize idle dim time and removed this option in this commit. After this patch, dim-idle-time was computed based on idle-delay (see @ruby answer) by dividing it by three. Few days later they decided that dividing by 3 is not good and changed this factor to 4/5 in this commit. Even though those arbitrary divider proved to be, well, arbitrary, they didn't restore any possibility to change this by user.
Note that Ubuntu is now using unity-settings-daemon which is a fork of gnome-settings-daemon with exactly the same code regarding screen dimming.
