How can I install Lubuntu 14.04 LTS on a non-pae processor? If it's not possible. Is there a work around for how to do it? It should be possible. Lubuntu is very low in system resources and perfect for old machines with a non-pae processor.
I am refurbishing a number of Pentium M laptops. Intel chose to disable PAE in these chips. I have used the "forcepae" command with mixed results.
This is how you do it using Lubuntu 14.04 LTS:
- Boot from the live CD and after you chose the language, and get the next screen
- HIGHLIGHT
Install Lubuntu - Press F6 and Esc and then add "forcepae" (no quotes) to the command line
- Press Enter
You get a warning and it may work about 30% of the time.
- 4,275
- 8
- 29
- 50
It is possible, you need to boot the Live USB with the forcepae boot option and then add this option to your boot options in GRUB in the installed system to make the change permanent.
- 415
try using Lubuntu grub-n-iso swap img.(burn it to usb stick) Then boot it into the live session. you replace the lubuntu iso stored in it's img file with 14.4 iso. but you have to rename it to lubuntu.iso.
after replacing the lubuntu.iso file with your iso ,then reboot the Lubuntu grub-n-iso swap img. From the live session u have running, just click "install" and instead of installing lubuntu it will install from your 14.4 iso.
NOTE:It was for a Dell D505 laptop ,which i think is pae capable but reports as non pae. i wrote about it a while ago here:
- 11
I admin some Pentium M notebooks. I have two CDs: 12.04 LTS NoPAE and 14.04 LTS Alternate. First, I install 12.04. Second, I install fake-PAE or build alternate kernel. Third, I run upgrade script from 14.04 CD. LTS-to-LTS upgrade works, but only with a CD, not with web-upgrade.
