I tried to install Ubuntu 11.04 several time using all the informations I could gather on the web. But I still fail to install it, and as my Vista partition contains very important informations I prefer to ask to people with some experience instead of doing a big mistake.
Here are my configuration:
Physical hard-drives:
  • (HD1) Hard-Drive1 ~300 Go (RAID 0 part 1)
  • (HD2) Hard-Drive2 ~300 Go (RAID 0 part 2)
  • (HD3) Hard-Drive3 ~640 Go (Data's)
- RAID 0 (HD1 + HD2) partitions:
  • Vista install (C:\ ~285)
  • Development (D:\ ~225)
  • The new empty partition for Ubuntu (40 Go)
- HD3 partitions:
  • My personal data's (~560 Go)
  • The second empty partition for Ubuntu (40 Go) because I was unable to install it the raid 0 drive.
The problem
When I install Ubuntu all seems ok until the following error:
Executing 'grub-install /dev/sda' failed.
This is a fatal error.
At that time, it offers me 3 options; select another destination, continue without Grub or Cancel the installation. When I try to select another destination (the one that seems to correspond to the Ubuntu partition according to gParted) is does nothing, and if I try to continue without Grub (I could install it later) a box with the following message appears:
We're sorry; the installer crashed...
I tried to install it on the RAID0 40Go partition, and later onto the HD3 40Go partition but both of them return the Grub error, and in the both cases I can't finalize the Ubuntu installation even without Grub.
Some informations
  • I use a USB key to boot and install Ubuntu (and it boots without problem).
  • The live session of Ubuntu start without any problem on the same computer.
  • I was able to install and run the same ISO on virtual box on the same computer.
  • The error occurs at almost 80-85% of the installation.
And finally, here are the informations returned by the Boot Info Script after cleaning the both 40Go partitions.
              Boot Info Script 0.60    from 17 May 2011
    ============================= Boot Info Summary: ===============================
     => Syslinux MBR (3.61-4.03) is installed in the MBR of /dev/sdb.
     => Windows is installed in the MBR of /dev/sdd.
     => HP/Gateway is installed in the MBR of /dev/mapper/nvidia_dffbicaa.
    sdb1: __________________________________________________________________________
        File system:       vfat
        Boot sector type:  SYSLINUX 4.03 2010-10-22 ........>..sr>..........:...0...~.....~...f...M.f.f....f..0~....>E}.u......
        Boot sector info:   Syslinux looks at sector 32144 of /dev/sdb1 for its
                   second stage. SYSLINUX is installed in the  directory.
                   The integrity check of the ADV area failed. No errors
                   found in the Boot Parameter Block.
        Operating System:
        Boot files:        /syslinux/syslinux.cfg /ldlinux.sys
    sdd1: __________________________________________________________________________
        File system:       ntfs
        Boot sector type:  Windows Vista/7
        Boot sector info:   No errors found in the Boot Parameter Block.
        Operating System:
        Boot files:
    sdd2: __________________________________________________________________________
        File system:       Extended Partition
        Boot sector type:  -
        Boot sector info:
    nvidia_dffbicaa1: ______________________________________________________________
        File system:       ntfs
        Operating System:  Windows Vista
        Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
    nvidia_dffbicaa2: ______________________________________________________________
        File system:       ntfs
        Operating System:
        Boot files:        /BOOTMGR /Boot/bcd
    nvidia_dffbicaa3: ______________________________________________________________
        File system:       ntfs
        Operating System:
        Boot files:
    ============================ Drive/Partition Info: =============================
    Drive: sdb _____________________________________________________________________
    Disk /dev/sdb: 4224 MB, 4224712704 bytes
    255 heads, 63 sectors/track, 513 cylinders, total 8251392 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
    /dev/sdb1    *             63     8,251,391     8,251,329   c W95 FAT32 (LBA)
    Drive: sdd _____________________________________________________________________
    Disk /dev/sdd: 640.1 GB, 640135028736 bytes
    255 heads, 63 sectors/track, 77825 cylinders, total 1250263728 sectors
    /dev/sdd1               2,048 1,168,340,983 1,168,338,936   7 NTFS / exFAT / HPFS
    /dev/sdd2       1,168,340,990 1,250,263,039    81,922,050   5 Extended
    Empty Partition.
    Drive: nvidia_dffbicaa _____________________________________________________________________
    Disk /dev/mapper/nvidia_dffbicaa: 600.1 GB, 600138055680 bytes
    255 heads, 63 sectors/track, 72962 cylinders, total 1172144640 sectors
    /dev/mapper/nvidia_dffbicaa1   *             63   598,870,014   598,869,952   7 NTFS / exFAT / HPFS
    /dev/mapper/nvidia_dffbicaa2      1,151,907,840 1,172,137,983    20,230,144  12 Compaq diagnostics
    /dev/mapper/nvidia_dffbicaa3        598,870,016 1,069,987,823   471,117,808   7 NTFS / exFAT / HPFS
    "blkid" output: ________________________________________________________________
    Device           UUID                                   TYPE       LABEL
    /dev/loop0                                              squashfs
    /dev/mapper/nvidia_dffbicaa1 F010DAB010DA7D52           ntfs
    /dev/mapper/nvidia_dffbicaa2 CA6E68D76E68BE37           ntfs       Respawn Recovery
    /dev/mapper/nvidia_dffbicaa3 34FCD7C1FCD77B94           ntfs
    /dev/sda                                                nvidia_raid_member
    /dev/sdb1        0810-0946                              vfat       PENDRIVE
    /dev/sdc                                                nvidia_raid_member
    /dev/sdd1        AA76186576183493                       ntfs
    ========================= "ls -R /dev/mapper/" output: =========================
    /dev/mapper:
    control
    nvidia_dffbicaa
    nvidia_dffbicaa1
    nvidia_dffbicaa2
    nvidia_dffbicaa3
    ================================ Mount points: =================================
    Device           Mount_Point              Type       Options
    /dev/loop0       /rofs                    squashfs   (ro,noatime)
    /dev/sdb1        /cdrom                   vfat       (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
    ========================= sdb1/syslinux/syslinux.cfg: ==========================
    # D-I config version 2.0
    include menu.cfg
    default vesamenu.c32
    prompt 0
    timeout 50
    # If you would like to use the new menu and be presented with the option to install or run from USB at startup, remove # from the following line. This line was commented out (by request of many) to allow the old menu to be presented and to enable booting straight into the Live Environment!
    # ui gfxboot bootlogo
    ================= sdb1: Location of files loaded by Syslinux: ==================
               GiB - GB             File                                 Fragment(s)
                ?? = ??             ldlinux.sys                                    1
                ?? = ??             syslinux/gfxboot.c32                           1
                ?? = ??             syslinux/syslinux.cfg                          1
                ?? = ??             syslinux/vesamenu.c32                          1
    ============== sdb1: Version of COM32(R) files used by Syslinux: ===============
     syslinux/gfxboot.c32               :  COM32R module (v4.xx)
     syslinux/vesamenu.c32              :  COM32R module (v4.xx)
    =============================== StdErr Messages: ===============================
    ./boot_info_script.sh: line 1579: [: 2.73495e+09: integer expression expected
Can any one, give me a hint or explain me why it doesn't work ?
Edit:
I removed the second hard drive for the moment, and then I did tried the install using the Ubuntu 11.04 Alternate ISO. The only choice available from the menu is Advanced Options / Rescue Broken System. Neither Run Ubuntu from this USB (probably normal) nor Install Ubuntu on a Hard Disk (is this normal ??) are available.
So I tried Rescue Broken System, and everything seems ok until the "Detect disks" step. It is asked the device to use as root file system and the choices are:
  • /dev/dm-1
  • /dev/dm-2
  • /dev/dm-3
  • /dev/dm-4
  • /dev/dm-5
  • /dev/sdc1
  • Assemble RAID array
  • Do not use a root file system
I tried with dm-4 and I was able to install GRUB and to finish the installation. Unfortunately, after rebooting, I went to Vista without any menu to book on Ubuntu.
Since that when I retry the Rescue Broken System, and when I select dm-4 as root file system, it offers me to Reinstall GRUB boot loader (which produce an error) and to execute shells, but I'm unable to continue to next step (Partition disks)
Does anything seems strange in this ?
Edit 2:
I finally managed to make GRUB work by reinstalling it on the /dev/mapper/nvidia_dffbicaa (known with the command # sudo dmraid -s).
When I boot on Vista it does work without any problem (pfuuu) but when I try to book the Ubuntu ou the Recovery Ubuntu, it fails.
Should I try to reinstall using the normal Ubuntu ISO (non Alternate) over this working Grub ?
Edit 3:
Ok the problem is solved. Here is how a achieved to do it.
1 - Cleaning of the 40Go partition
2 - Boot on Ubuntu Alternate Recovery Mode, and use of the main menu (ESC) to create the partitions (swap and ext4) and assemble the raid, then setup Grub using the RAID name (/dev/mapper/theRaidName) instead of /dev/sda.
3 - Boot on Ubuntu Normal, then proceeding to install normally until the Grub error...
4 - Reboot and all is there.
Valkea
  • 185
I'm pretty sure that you need to use the Alternate CD if you are going to install Ubuntu into a RAID condition. The installer is text based, but has more capabilities than the one found on the live CD image, or USB key image.
Please read the documentation here: https://help.ubuntu.com/community/FakeRaidHowto
bertmanphx
