I edited the xconf file, and added this line to device section:
Enable brightness control=1
Now I am able to adjust brightness, but after every restart the brightness setting change back to 100%.
Is there any solution for this?
Braiam
  • 69,112
Manu
  • 49
6 Answers6
To adjust brightness in xubuntu or ubuntu Open a terminal window, and execute this command to edit /etc/rc.local:
sudo nano /etc/rc.local
Add this before the last line “exit 0″:
echo xx > /sys/class/backlight/acpi_video0/brightness
Where number xx is the value of your screen brightness of your choice.
The maximum value for brightness can be found with:
cat /sys/class/backlight/acpi_video0/max_brightness
Charles Green
  • 21,859
Fix brightness control issue with Intel card in Ubuntu:(check which card is there:settings/details/graphics)
Open a terminal and create the following configuration file, if it does not exist:
touch /usr/share/X11/xorg.conf.d/20-intel.conf
Now we need to edit this file. You can use any editor be it a terminal one or graphical.
sudo gedit /usr/share/X11/xorg.conf.d/20-intel.conf
Add the following lines to this file:
Section "Device"
        Identifier  "card0"
        Driver      "intel"
        Option      "Backlight"  "intel_backlight"
        BusID       "PCI:0:2:0"
EndSection
Save it. Log out and log in back. The brightness control should be working through function keys now:
aayush
  • 39
create a file in /usr/share/X11/xorg.conf.d/80-backlight.conf and include following in the file.
Section "Device"
    Identifier "Intel Graphics"
    Driver "intel"
    Option "AccelMethod" "sna"
    Option "Backlight" "intel_backlight" # use your backlight that works here
    BusID "PCI:0:2:0"
EndSection
Gayan Charith
  • 565
In /etc/default/grub make sure you have acpi_backlight=vendor in GRUB_CMDLINE_LINUX_DEFAULT.
Here is mine:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Then run update-grub and reboot.
Fixed it for me, HP ProBook w/ Intel Grpahics card, fresh 14.04 Desktop install.
kraxor
  • 5,627
Jmills
  • 121
Type this command in Terminal:
xrandr --output LVDS-0 --brightness 0.5
0.5 is used to decreased to adjust screen Brighness.
Should work Perfectly.
if not
xrandr --output LVDS1 --brightness 0.5
will do the job
Eric Carvalho
  • 55,453
If you want to change the screen brightness in Ubuntu
(I can’t change it using the keyboard shortcuts or the Ubuntu Power Management menu),
open a terminal and execute the following:
sudo setpci -s 00:02.0 F4.B=xx
Where xx is the desired brightness in hex ranging from 0 (brightest) to FF (no brightness at all). I usually change it to E0 when working on battery.
