We have an AWS server running OpenVPN which was built using Ubuntu 13.10. After the announcement of the Heartbleed vulnerability, we updated the server. This morning, we upgraded the server to 14.04. The current output of "openssl version -a" is:
OpenSSL 1.0.1f 6 Jan 2014
built on: Mon Apr  7 21:22:23 UTC 2014
platform: debian-amd64
options:  bn(64,64) rc4(16x,int) des(idx,cisc,16,int) blowfish(idx)
compiler: cc -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -m64 -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wa,--noexecstack -Wall -DMD32_REG_T=int -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DWHIRLPOOL_ASM -DGHASH_ASM OPENSSLDIR: "/usr/lib/ssl"
I verified the fact that the server is still vulnerable using the following:
:~$ openssl s_client -connect openvpn.example.com:443 -tlsextdebug 2>&1| grep 'server extension "heartbeat" (id=15)' || echo safe
TLS server extension "heartbeat" (id=15), len=1
Attempts to run "sudo apt-get install openssl" return that the current version is already installed. What are the best options to resolve this issue? Does it appear there was a problem during distribution upgrade; i.e. is the 14.04 OpenSSL package actually outside the danger range? Or is there a possible issue with the repository itself?
Braiam
  • 69,112
As @david6 pointed out, the version of OpenSSL might still appear to be a vulnerable version. This is because Ubuntu, as many other distros, backports security fixes rather than updating to a whole newer version of the software (and possibly picking up new features and their attendant bugs along the way). So, just because you're running a "vulnerable version" of OpenSSL doesn't mean you're running a vulnerable version of OpenSSL.
However, if the available Heartbleed audits indicate you're still vulnerable, you're still vulnerable.
What I think is going on is that you've updated the package, but you haven't restarted the services that use OpenSSL, so they are still holding on to the older version that they loaded at startup.
There are two easy ways to fix that:
  1. Reboot the server.
  2. Identify and restart the affected services. An easy way to do this is with, checkrestart from the debian-goodies package. It should identify the affected services and even tell you what init scripts will restart them:
    $ sudo apt-get install debian-goodies
    $ sudo checkrestart
tgies
  • 509
You are right to be concerned.
However, to no longer be vulnerable to OpenSSL / Heartbleed on Ubuntu, you just need to be using an updated compile of the OpenSSL library.
The command openssl version -a should show that new date: 'built on: Mon Apr 7'
Actual examples:
(1.) Ubuntu 14.04 LTS (64bit, desktop) - upgraded from 13.10
(2.) Ubuntu 14.04 LTS (64bit, desktop) - NEW install
(3.) Ubuntu 12.04 LTS (64bit, server) - fully updated
OpenSSL 1.0.1 14 Mar 2012
built on: Mon Apr  7 20:33:29 UTC 2014
NOTE:
  • Ubuntu maintainer have a lengthy testing cycle before they will 'replace' a library with a brand new version (with differing features). The simple fix for this bug was to either add bounds-checking logic (for the heartbeat function) or to compile with a flag (pragma) to exclude the heartbeat functionality entirely. These two options will not adversely impact any other applications or services.
  • If you had installed a version of OpenSSL v1.0.1 (or v1.0.2 beta) from source, or download a binary (for Ubuntu) from somewhere, then you would indeed be vulnerable unless you were using v1.0.1g (or the compile option had been used to remove 'heartbeat'). Only use trusted sources.
david6
  • 14,528
  • 38
  • 46
-1
Upgrade to the latest and you'll be okay if you are running on Ubuntu for CVE-2016-2107: see https://forums.openvpn.net/viewtopic.php?f=4&t=21699&p=62376#p62376
If you dpkg the current openvpn_as server you can see it's updated for openssl past the bug:
jonathan@Jonathan-Les-MacBook-Pro:~/Downloads/openvpn/usr/local/openvpn_as/lib/pkgconfig$ cat openssl.pc
prefix=/usr/local/openvpn_as
exec_prefix=$
{prefix}
libdir=${exec_prefix}/lib64
includedir=${prefix}
/include
Description: Secure Sockets Layer and cryptography libraries and tools
Version: 1.0.2h
Requires: libssl libcrypto
For CVE-2016-2107 in https://www.openssl.org/news/secadv/20160503.txt: "OpenSSL 1.0.2 users should upgrade to 1.0.2h"
We upgraded to the latest and are A-OK now
muru
  • 207,228
